    Dismiss Notice
NonInverting Amp
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by herbymcduff, Dec 19, 2002.
  1. herbymcduff
    herbymcduff New Member
    Dec 5, 2002
    205
    0
    USA
    I need help with this one. I'll give parts needed and a description of what I need.
    Parts:
    1 op amp
    1 cap
    Resistors
    1 POT
    Can you draw me a noninverting amp that will take a 500mV p-p low level signal and amplify it to 100mV p-p to 2V p-p (adjustable)
    I was just wanting to see what any of you guys or girls come up with. I want to compare it to mine and see if mine is correct or not.
    The trouble I have, is that in my mind I don't think you can get out 100mV p-p. Mainly because gain is determined by RF/R1 +1 right. So even if you had a gain of .1 on the inverting, +1 you would get 1.1. With an output voltage of .550mV p-p.
    After thinking about it for awhile, I finally came up with putting a voltage divider on the noninverting input. If I am right, I don't know. That's why I am asking you.
    Thanks.
  2. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Potential divider will work just fine as you want. Just keep the gain of op-amp to 4 so that when the input is 500mV and the potential divider is set for minimum attenuation, the output will be 500*4=2000mV=2V.
    To get 100mV for 500mV input, adjust your potential divider such that the input signal to NI pin is 25mV. The output is this case will be 25mV*4=100mV.
    Bye the way where are you going to use that capacitor which you mentioned in your list?
  3. herbymcduff
    Dec 5, 2002
    205
    0
    USA
    Since I'm putting in a AC signal, I'm using the cap to block DC coming in on the noninverting input.
Share This Page
