    Dismiss Notice
New using PIC18F4520 with C Programming
Discussion in 'Microcontrollers' started by mrfunkyjay, Apr 22, 2008.
  1. arhi
    arhi Member
    Apr 17, 2008
    887
    12
    Belgrade, .rs
    yup, I use C 99.9% of time but I was thinking more in course of
    Code (text):
    while(1){
      asm('rrf PORTD,1');
    saves the ram for that extra variable you would use to rotate/shift and then assign to port..
  2. mrfunkyjay
    mrfunkyjay New Member
    Mar 26, 2008
    123
    0
    Jakarta, Indonesia
    Thanks!! I know know how it works, wanna try some. Thanks!!
  3. mrfunkyjay
    Mar 26, 2008
    123
    0
    Jakarta, Indonesia
    The first program of mine!!! With helps from u guys! Thank u so much!!
    I need to change to PIC18F4580 because my PIC18F4520 is worn out. Hmm...
    Code (text):
    /*This program tells a series of LEDs in PORTD to flash (by pressing Push Button RA4) one by one in forward direction, from RD0 to RD7.*/
    /*When it reaches RD7, backward direction executed from RD7 to RD0 again. When PB RA4 is pressed again, the whole system stop. */
    #include <p18f4580.h>
    #include <delays.h>
    #pragma config OSC = HS
    #pragma config WDT = OFF
    #pragma config LVP = OFF
    int i, iKey, iPrevious;
    unsigned char cShift=1; /*Declaring shift bit interval*/
    unsigned char cPBState=1; /*State of the Push Button*/
    void vFlashing(void); /*Declaring flashing mode1*/
    /*Flashing Mode*/
        if (cShift==15) /*Count cShift to 15x*/
            cShift=1; /*Restarting cShift value*/
        if (cShift<8) /*When cShift smaller than 8*/
            LATD=0b00000001<<cShift; /*Forward flash*/
            Delay10KTCYx(50); /*Delays*/
            cShift++; /*Increment cShift*/
        else /*When cShift bigger than 8*/
            LATD=0b10000000>>(cShift-7); /*Backward flash*/
    /*Main Function*/
    void main(void)
        /*Settings*/
        TRISD=0b00000000; /*Declaring all PORTD as an Output Port*/
        TRISA=0b00010000; /*Declaring RA4 as an Input Port*/
        /*Initializing*/
        iKey=0;
        cPBState=1;
        while(1) /*Loop Forever*/
            iPrevious=iKey; /*Copy the last value*/
            iKey=PORTAbits.RA4; /*Assigning new value*/
            /*Push Button RA4 Function ON/OFF Button*/
            if(iKey==0 && iPrevious==1) /*Getting information*/
                if(cPBState==0) /*Changing the PBState*/
                    cPBState=1;
                else
                    cPBState=0;
                switch (cPBState) /*Switch function for cases*/
                    case 0:
                    vFlashing(); /*If case 0, do flashing1*/
                    break;
                    case 1: /*If case 1, do nothing*/
                    break;
                    default:
                    break;
    Okay, I want to ask a question now:
    If I want this thing on a small pcb (not on a demo board), is it possible to make PCB layout according to the data sheet of this MC and make all the Vcc and GND and all of their routes, making PORTD as an output, say I connect them with connectors so I can drive several LEDs??
    Is that how these things work??? Is that how ppl out there makin MCU as "brain" of their PCB or system, I would say. ??
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. hong9088
    hong9088 New Member
    Nov 16, 2008
    1
    0
    Help is needed. Thanks :)
    Hey sorry i'm new here. Just to ask how do i make the LED blink(using C program statements) Light up a combination of LEDs on the target board(using C program statements) Light up a LED when a switch is pressed (using C program statements). I'm a student and i'm doing some research on it. But i can't get to find any help regarding the Question above. Can anyone help me out? Thanks lots:)
  6. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,015
    317
    Brisbane Australia
    ONLINE
    To get you started, clicky.
Share This Page
