!!!NEED HELP!!!add in recorder voice in 18f4520
caltex
hi guys,
how do i add in a pre-recorder voice in the pic....and output it out through a speaker???
many thanks for your replies......
Store the audio data as a table in the program memory, them read it sequentially and play it back out through a digital to analogue converter. Don't forget the low pass filter after the D2A.
hi, i've converted the audio data to .asm table already. The problem now is, what is the code to play the audio? how shld i write it?
sorry about it.. im quite new to programming PIC
Read from where you store the audio data, then use external DAC, either serial or parallel interface. You may need to amplify the converter's output.
Read first entry, output to D2A, delay for next byte.
Read second entry, output to D2A, delay for next byte.
Repeat until all done.
The delay time is dependent on your sampling rate.
