I have 16 resistors that are all Red Yellow Brown, my digital meter shows their actual values are 214 ohms to 298 ohms, none are 240 ohms.
Circuit drawing calls for 240 ohms. The closest thing I have is 245 and 249 ohms. The only way I can get exactly 240 ohms is put some higher value resistors in parallel.
R1 and R2=240 ohms.
Di and D2 =1N5818
Mosfets =STP55NF06, 60v, 50a, .016 ohm
Choke= 8uh, 35a
C1=.47 uf x8
Coil= 8T, 1"dia 1.5L
What I would like to know is, what does wrong none matching resistor do to this circuit???
I have learned if I change the resistor from 240 to 200 the mosfets run hotter but I don't know the real ohm value I did not test the 200 ohm resistors with my meter. I also notice every time a mosfet burns out it is always the same mosfet. I am guessing current is higher in the mosfet that fried because of miss matched resistors?
R1 and R2=240 ohms.
Di and D2 =1N5818
Choke= 8uh, 35a
C1=.47 uf x8
