ElectroMaster
Administrator
ElectroMaster submitted a new article:
Modular Burglar Alarm - This circuit features automatic Exit and Entry delays and a timed Bell Cut-off. It has provision fo
Read more about this article...
This circuit features automatic Exit and Entry delays and a timed Bell Cut-off. It has provision for both normally-closed and normally-open contacts, and a 24-hour Personal Attack/Tamper zone. It is connected permanently to the 12-volt supply and its operation is "enabled" by opening SW1. By using the expansion modules, you can add as many zones as you require; some or all of which may be the inertia (shock) sensor type. All the green LEDs should be lighting before you open SW1. You then have...
