    Dismiss Notice
mobile phone battery specifications...
Discussion in 'General Electronics Chat' started by rocky06, Feb 1, 2010.
  1. rocky06
    rocky06 New Member
    Dec 17, 2006
    14
    0
    Guys.... i need some help in fetching informations about a mobile phone battery lik its impedance , current rating , to charge it how much current and power required & what should be the charger's impedance....etc..... where can i get those infos.. pls help me get those....
  2. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,044
    541
    AZ 86334
    Take back off cell phone. Look at battery. Battery voltage and chemistry should be printed on battery. Google that type of battery...
  3. RCinFLA
    RCinFLA Well-Known Member
    Jul 23, 2009
    1,065
    31
    FLA, USA
    Mobile phone batteries range from about 700 mA-hrs to 1200 mA-hrs. Smart phones have larger in 1000 - 1300 mA-hrs range.
    Rs of battery starts out about 0.15 ohms and degrades as it is cycled. At 300-400 cycle the Rs may double.
    Charging depends on manufacturer. Typically about 0.2 to 0.6 of mA-hrs rating current. Li-Ions need several safety failsafe measures for charging. The two most important are never charge a battery that is below 1.8 vdc and charger voltage must not exceed 4.25 vdc. A battery less then 3.0vdc needs a <0.1C trickle charge until voltage comes up to about 3.4 vdc.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    Rc where'd you get that bit about a battery of less than 3.0vds needs a trickle charge till 3.4 volts? I'm curious as to the reasons.
  6. RCinFLA
    Jul 23, 2009
    1,065
    31
    FLA, USA
    It is specified in IEEE1725 as a requirement but left up to battery manufacturer as the voltage limits. 3.4v is probably conservative. It is okay for most LiIon's to go to full rate charging at about 3.2 vdc. The trade off is how long to get a device alive after hooking up charger. An unload LiIon will not support much load until it gets above 3.6- 3.7vdc, but charger could support load sooner.
    Most of the safety items have to do with plating out Lithium and I believe the precharge is to ensure enough charge state uniformity to avoid the issue.
  7. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    Thanks for the reference, I didn't realize there were even any specs for battery charging lithium-polymer cells like that. I've bookmarked the standard for later reading. Nice to see some companies are at least trying to put this stuff down on paper standards.
  8. sakura88
    sakura88 New Member
    Feb 3, 2010
    1
    0
    I think that it can help you
  9. rocky06
    rocky06 New Member
    Dec 17, 2006
    14
    0
    thanks for ur comments guys... it was helpful...... now i got a new prob... can i boost current from from nA to some usable value..... say for lightin an array of LEDS or just to charge a li-ion battery... any feasible ideas guys.... hope u experts help me to solve this prob...
  10. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    ??? Regardless of voltage, nano amps are particularly useless, what do you have in mind? As you haven't actually asked a question yet, just some vague concept of converting nano amps to 'useful value' which makes no sense out of context of what you're trying to do.
  11. rocky06
    rocky06 New Member
    Dec 17, 2006
    14
    0
    oops.... sorry i was about to ask to boost uA to some usable value when the voltage is around 5 or 6v.....
  12. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    To increase current you'd need to decrease voltage. 5 times the current 1/5th the voltage, and that's with a 100% efficient converter, even good converters are only around 80-90% efficient and that's with more voltage headroom than you have. I think you'd be lucky to get 50% efficiency, and you'd end up with still not enough power to be useful for much.
Share This Page
