Microcontroller
i want to compile this code in KEIL but i am getting an error please check it out and help me, i have started learning microcontroller just now
// -=-=-=-=- Hardware Defines -=-=-=-=-=-=-=
sbit SENSOR = P1^0; //sensor is connected to this pin
unsigned int beatms;
float bpm;
char buf[20]; // -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
// -=-=-=-=- Main Program -=-=-=-=-=-=-=
void main()
{ // -=-=- Intialize variables -=-=-=
lcdInit(); // -=-=- Welcome LCD Message -=-=-=
lcdClear();
lcdGotoXY(0,0); // 1st Line of LCD
// "xxxxxxxxxxxxxxxx"
lcdPrint("DIGITAL HEART");
lcdGotoXY(0,1); // 2nd Line of LCD
lcdPrint("BEAT MONITOR");
beatms=0; // will store duration between two pulses
// -=-=- Program Loop -=-=-=
while(1)
while(SENSOR==0);// wait for high pulse from sensor
DelayNmS(10); // 10ms delay so that it does not listen to any noise
beatms = 10; // start counting beatms from 10ms since we have delay after pulse
while(SENSOR==1)// wait until signal is high
DelayNmS(1); //wait 1msec
beatms++; //keep incrementing counter each 1ms
while(SENSOR==0) //keep looping till signal goes back high, wait for next
} // beatms variable will now have time in ms between two high edge pulse
lcdClear();
lcdGotoXY(0,0);
lcdPrint("HEART RATE : ");
bpm = (float)60000/beatms; // see document of #1157 for this calculation
if(bpm > 200)
lcdGotoXY(0,1);
sprintf (buf, "Processing......"); // Invalid, Wait for next cycle
lcdPrint(buf);
} else {
lcdGotoXY(0,1);
sprintf (buf, "%0.0f BPM", bpm); // Display reading in BPM
lcdPrint(buf);
i am using at89c52 micro controller. please help me.
from where i can get these header files ? i am new at microcontroller :( so i dont know much about its programming so please help me !
sprintf() is in stdio.h..... If you include this line
#include <stdio.h>
Then you will be able to use it.
However!! The standard output is on the standard serial TX pin.... If you need to direct it elsewhere you need to check your compiler documentation...
