    Dismiss Notice
making a 12v to 240v power inverter
Discussion in 'Alternative Energy' started by jahan002, Apr 26, 2009.
  1. jahan002
    jahan002 New Member
    Apr 26, 2009
    3
    0
    first of all i will like o that this my first post and that i am a novice when it comes to electronic.
    I purchased a solar panel which as the following spec:
    Optimum working voltage of :- 17.5V
    Optimum working current of:- 260mA
    Peak power output:- 4.8W
    I want create an inverter that will convert the power from the solar into 240V
    i have a UPS which i can get some hardware from. thanks in advance.
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,323
    653
    Derbyshire, UK
    Just use the panel to charge a battery, the inverter runs from the battery.
    However, it's such a tiny panel, what do you expect to run from it?.
  3. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,573
    950
    Canada, of course!
    Its very low power can charge a battery that will blink a 10W light bulb one time each week.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. jahan002
    jahan002 New Member
    Apr 26, 2009
    3
    0
    thank you for the reply
    i will tria and get a more powerfull panel
  6. jahan002
    jahan002 New Member
    Apr 26, 2009
    3
    0
    i am looking forward to powering my laptop with it.
  7. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    After a sunny 8-hour day of charging you will be lucky to get 15 minutes of laptop usage.
  8. SPDCHK
    SPDCHK Member
    May 26, 2006
    446
    17
    South Africa
    Laptops consume in the region of 50W PLUS power.
    Power Out = Power In - Losses.
    You will need at the least 10 times the panels you’ve mentioned.
    And remember, even though sunlight is for free, everything else will come at a cost. I don't have the correct figures, but I do not believe (unless it's a unit designed by someone like TCMTECH), that you will get efficiency of greater that 60% from a home made inverter, so that will make the count of 10 times panels also not enough.
    4.5W will be enough to power a LED flash light though. :D
    • Like Like x 1
  9. tcmtech
    tcmtech Well-Known Member Most Helpful Member
    Feb 22, 2009
    6,693
    431
    Sawyer, North Dakota, USA
    I'd say your about right on the 60% efficiency range.
    If you were to use modern schematics and good modern day parts with designs based on actual data sheet information related to those parts, A low frequency iron core transformer based inverter could conceivably hit 85% efficiency.
    But you would need a good quality transformer that has an honest 90% or higher efficiency. And still that would require the control circuits and switching devices to stay under 5% total loss.
    I honestly could not guarantee that number either (and make an actual clean sine wave any way)!
    75 -80% would be more realistic.
    The low end non sine wave HF inverters run about 85% on average and the good high efficiency ones do have ratings above 90% now.
    But given the tiny solar panels actual output I would still agree with everyone else and charge a battery with it and use the accumulated power.
  10. tcmtech
    Feb 22, 2009
    6,693
    431
    I rethought it and at that low of available power I doubt you could even hit much higher than 35% efficiency realistically.
    The control circuit and switching devices would consume about 1.5 watts. The step up transformer (iron Core wall power pack type) at that small of size is going to be at best 50% efficient.
    Given 4.8 - 1.5 = 3.3 3.3 * 50% = 1.65 watts. 1.65/4.8 = 34% efficiency.:(
    1.65 watts at 240 volts is around .0069 amps! You might run a mini neon indicator light to tell you your inverter is on but then you would have no power left to work with! :p
    Maybe make up a set of mini padles and use it to restart a hampsters heart! or electrocute some bugs! :D
    Sorry to rain on your parade. At least now you have some idea of what your working with!
    However with 4.8 watts available at 17.5 volts or less you have loads of small electronic devices you could build or power with it! :)
  11. Thunderchild
    Thunderchild New Member
    Jul 3, 2005
    2,294
    9
    UK
    good luck, I have 2 X 20 W panels and I make enough iin a day to run one LCD computer monitor. if your going to run a laptop off it why not get a laptop power supply for use in a car so that it takes the power straight from the battery. you are proposing to charge a car battery and in this process not all of the power will result in a charged battery, then you are going to conver the 12 V DC to 240 V AC and in this process you will loose 10-15 % of the power, you will then reconvert 240 V AC down to the laptops voltage at DC and loose a further 15 % so by the time you finish you have about 75 % of what you started with. whereas if you directly use the battery to power a laptop power supply you cut out one stage and recover more power.
  12. electronrancher
    electronrancher New Member
    Apr 2, 2009
    9
    0
    A laptop input is only 14-20v DC. So to convert your DC to 240v AC and back again is a big waste.
    I'd suggest using a buck-boost DC-DC converter to convert that varying DC panel voltage into a fixed 19v (for example) to charge your laptop. You should get 85% at very worst case.
  13. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    Search eBay using keywords auto laptop power and you will see about 131 hits which offer devices of this kind, starting at about US$18. I bought one and I'm extremely happy with it.
    Or you could design and build one.
  14. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    A single 12V panel will probably be able to charge three 6V SLAs in series.
    The 12V panels I have put out 26V each and their maximum power rating is taken at 17.5V.
  15. Thunderchild
    Jul 3, 2005
    2,294
    9
    UK
    in which case they can't charge 18 volts of battery as you need 20-21 volts and you have maximum output at 17.5 volts best thing is use 12 volts and a chargin regulator
Share This Page
