Hey all,
I'm simulating a really simple circuit (op-amp driving two transistors in a push-pull configuration). When I do an AC Analysis and compare the input and output, the input looks great (10Vpp signal as I set) but the output shows a voltage going to nearly 110V!
Maybe I'm doing something wrong? I have two voltage sources, +15 and -15 connected to the net +V and -V respectively and these are the net names that I'm using on the power of the op-amp and as power where required in the circuit.
FWIW, I've set the simulation results to Bode - Linear.
