LTSpice, Importing Diodes Inc. Spice Models
Ah, I assume "nmos" isn't correct as it's a subcircuit, but how in earth do you find where the subcircuit is when you go "add component"?
*NMOS
.SUBCKT DMC4040SSDQ 10 20 30
* TERMINALS: D G S
M1 1 2 3 3 NMOS L = 1E-006 W = 1E-006
RD 10 1 0.01247
RS 30 3 0.001
RG 20 2 1.29
CGS 2 3 1.225E-009
EGD 12 0 2 1 1
VFB 14 0 0
FFB 2 1 VFB 1
CGD 13 14 1.7E-009
R1 13 0 1
D1 12 13 DLIM
DDG 15 14 DCGD
R2 12 15 1
D2 15 0 DLIM
DSD 3 10 DSUB
.MODEL NMOS NMOS LEVEL = 3 VMAX = 5.378E+005 ETA = 0.001 VTO = 1.378
+ TOX = 6E-008 NSUB = 1E+016 KP = 59.42 U0 = 400 KAPPA = 10
.MODEL DCGD D CJO = 5.583E-010 VJ = 0.6 M = 0.6
.MODEL DSUB D IS = 1.44E-009 N = 1.222 RS = 0.009951 BV = 47 CJO = 1E-015 VJ = 0.6 M = 0.7823
.MODEL DLIM D IS = 0.0001
.ENDS
*PMOS
* TERMINALS: D G S
M1 1 2 3 3 PMOS L = 1E-006 W = 1E-006
RD 10 1 0.006043
RS 30 3 0.001
RG 20 2 6.43
CGS 2 3 1.554E-009
EGD 12 30 2 1 1
VFB 14 30 0
FFB 2 1 VFB 1
CGD 13 14 1.4E-009
R1 13 30 1
D1 13 12 DLIM
DDG 14 15 DCGD
R2 12 15 1
D2 30 15 DLIM
DSD 10 3 DSUB
.MODEL PMOS PMOS LEVEL = 3 U0 = 400 VMAX = 1E+006 ETA = 4.441E-010
+ TOX = 6E-008 NSUB = 1E+016 KP = 11.66 KAPPA = 9.057 VTO = -1.385
.MODEL DCGD D CJO = 5.62E-010 VJ = 0.6 M = 0.4221
.MODEL DSUB D IS = 4.586E-010 N = 1.275 RS = 0.01773 BV = 50 CJO = 2.892E-010 VJ = 0.0947 M = 0.3174
.ENDS
Nothing (no Diodes Inc devices
file "standard.dio" found at c:\program files\ltc\.......cmp\ (depends on which windows version)
can be edited in LTC or any text editor.
I added this to the top line of the file and saved.
Note what is bold needed to be added by hand.
Remove any " + ". or keep it all on one line.
.model UF1001 D(IS=125u RS=17.5m BV=50.0 IBV=5.00u CJO=79.6p M=0.333 N=3.75 TT=72.0n Iave=1 Vpk=50 mfg=Diodes type=silicon)
Iave= (amp rating ), Vpk= (voltage max), mfg= name of company, type= silicon/zener/etc
OK, so what's the point in the subcircuit folder?
These standard.* files are in LTspice specific format? If it's possible to drop in SPICE files and use them I'd be happier!
I don't know how to add a spice sub folder ...... (maybe that is how I created ICs)
I do know how to add to the "standard" file.
If I used spice more (looking for a job like that) I would import lists like from "diodes inc" and modify them in an editor/spreadsheet then save them for backup. I really want my standard files to be much longer. (years ago my files were 3x longer)
Thing is if I do that chances are I'll miss off some of the characteristics and it might come to bite me in the prototype. I've been prototyping before simulation and I must stop! :)
I figure
Is the data I need from the subcircuit, but the ltspice format looks to be quite different:-
.model IRFP240 VDMOS(Rg=3 Vto=4 Rd=72m Rs=18m Rb=36m Kp=4.9 Lambda=.03 Cgdmax=1.34n Cgdmin=.1n Cgs=1.25n Cjo=1.25n Is=67p ksubthres=.1 mfg=International_Rectifier Vds=200 Ron=180m Qg=70n)
Sorted!
It's a long winded video which explains it:-
Essentially right click on component while holding control, change Prefix to capital X, value to the subcircuit name. Add a spice directive (.OP button) to include the subcircuit file.
