    Dismiss Notice
lightning
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by scottyish, Oct 26, 2002.
  1. scottyish
    scottyish New Member
    Oct 26, 2002
    1
    0
    :?: Need help designing a circuit to create lightning effects, preferably with flourescent lights for Halloween. Thanks.
  2. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    What kind of effect do you want? Sequential or random?
    If you want sequential effect the simplest method is to use Decade counter IC 4017. The IC has 10 outputs which shift one by one when a clock signal is fed to it. Use 555 IC in astable mode (low frequency) to generate clock for 4017 . The output of 4017 can be used to drive triacs with the help of small signal transistors like BC547. The lamp loads should be connected to triacs.
    For Random effect you can use a simple microcontroller. But you got to know the programming of it before using it.
    Kinjal
  3. star882
    star882 New Member
    Sep 26, 2002
    36
    0
    Try a strobe for the flash.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Mikkel
    Mikkel New Member
    Nov 18, 2002
    5
    0
    Norway
    How do you the drive triacs with the help of small signal transistors?
  6. kinjalgp
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    This way:
    [​IMG]
  7. kinjalgp
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    This way: The value of R1 is 1k
    [​IMG]
  8. mechie
    mechie New Member
    Sep 4, 2002
    591
    3
    Lincolnshire, England
    Caution
    I don't mean to nit-pick but just in case anyone isn't aware ...
    The driver circuit above will cause your whole circuit to be potentially LIVE ! - the mains is connected to your logic circuit ground rail so be careful. Make this the mains Neutral (for those lucky enough to have a neutral ?) but NEVER assume it to be a safe voltage !.
  9. kinjalgp
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    I have tried it with both ways i.e. neutral and live but in both cases circuit is dangerous to touch sp beware :twisted:
  10. Phasor
    Phasor Member
    Aug 14, 2002
    703
    0
    Sydney, Australia
    Just a thought - You could use an optoisolated triac driver if you want to separate the logic and the load.
  11. kinjalgp
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Yes even thats a better and safe option. :idea:
  12. Mikkel
    Mikkel New Member
    Nov 18, 2002
    5
    0
    Norway
    Thanks for the circuit, Kinjalgp
    I wanted this circuit because i couldn't get triac optoisolators
Share This Page
