led blinking speed using up/down push buttons ( pic16f883).
zain kaleem
Hi
I am working on simple project. I just want to create the blinking led with variable delay. I have connected two push buttons for increment and decrement the delay value to blink the led. I am using PIC16F883 on proteus simulation and for programming MPLAB IDE. My code is not working correctly. The value for the delay is not changing.
Can anybody help me with this ?
Here is the complete code.
#include <xc.h>
#include "confi.h" // header file for configuration settings.
void delay(unsigned int x);
unsigned int speedstep=0;
void main(void) {
unsigned int x,y;
TRISC0=1;
TRISC1=1;
TRISC2=0;
PORTCbits.RC2=0;
while(1)
RC2=1;
delay(y);
RC2=0;
delay(y);
if (PORTCbits.RC0 == 0) //was the increment button pushed?
for(x=0; x<500; x++) //debounce switch
speedstep++; //increment speedstep variable by 1
y = speedstep;
while(PORTCbits.RC0 == 0);//show variable value on port c
if (PORTCbits.RC1 == 0) //was the decrement button pushed?
speedstep--; //deccrement speedstep variable by 1
y = speedstep; //show variable value on port c
while(PORTCbits.RC1 == 0);
void delay(unsigned int x){
for(int i=0; i!=x; i++)
NOP();
__delay_ms(1);
It worked.
when I increment the delay it also increases but when I decrement the delay the led just stays ON.
how can i know that how much delay is used by the led??
EDIT:
serial.print( y, DEC);
serial.print( speedstep,DEC );
is a great way to evaluate the variables
put your code in code-takes so it is readable
If you add indentation to your code and then use code tags, you get this,
#include <xc.h>
void main(void){
unsigned int x,y;
TRISC0=1;
TRISC1=1;
TRISC2=0;
PORTCbits.RC2=0;
    while(1){
        RC2=1;
        delay(y);
        RC2=0;
        delay(y);
        if (PORTCbits.RC0 == 0){ //was the increment button pushed?
            for(x=0; x<500; x++); //debounce switch
            y = speedstep;
        if (PORTCbits.RC1 == 0){ //was the decrement button pushed?
        NOP();
It's much more readable and easier for people to follow.
I can't see why you have the problem you do.
Edit, speedstep is unsigned int initialised as zero. It get decremented to 65535. Are you waiting long enough? That's 65 seconds - over a minute.
