    Dismiss Notice
LCD backlight problem? inverter problem? SHARP
Discussion in 'Repairing Electronics' started by dirtyb15, Jun 4, 2009.
  1. dirtyb15
    dirtyb15 Member
    Apr 8, 2005
    75
    0
    OHIO
    Hi all. i Have an older sharp lcd tv 37" that someone just gave me because it has an intermittent backlight problem. It is in great shape otherwise so id like to fix it if i can. Basically the backlight wont turn on 19 out of 20 times when you power the tv up. Eventually if you unplug it and plug it in it will turn on , and its fine till you power the tv off.
    When it finally does turn on it says it had a lamp error and i have to reset the error.
    I really dont want to leave it on 24 hours a day and im hoping i can fix it. Does this sound like a faulty inverter? If so, can this be repaired or do i need to find another board?
    Thanks in advance for any help.
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    You don't mention the model?, but - and you'll probably like this! :D - a number of the older Sharp models had a problem with the earthing screws on the inverter becoming loose, causing it to shut down. You can simply make sure they are tightened properly, or Sharp provide some modified screws to replace them, basically screws with shake-proof washers built-in.
    If that doesn't cure it, again depending on model, on some you need to replace the large string of opto-couplers on the inverter board.
    But if you're lucky, it's just the screws.
  3. dirtyb15
    dirtyb15 Member
    Apr 8, 2005
    75
    0
    OHIO
    Thanks for the reply nigel, ill try that!. The set is at home or i would have posted the model number (cant remember off hand.) It has the seperate box for inputs ect, so it is older.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Nigel Goodwin
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    As you're the other side of the Atlantic the numbers are likely to be completely different anyway.
  6. dirtyb15
    dirtyb15 Member
    Apr 8, 2005
    75
    0
    OHIO
    Well, there are 4 inverter boards, and i tightened all the screws (seemed tight already), and same symptoms. What should i check next? I have the model number now, its a LC-37HV4U
  7. Nigel Goodwin
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    The European models are LC-37HV4E and LC-37HV4EB, I've checked the technical bulletins, there's nothing listed on either of those two models.
    Do you have the circuit diagram?.
  8. dirtyb15
    dirtyb15 Member
    Apr 8, 2005
    75
    0
    OHIO
    I do not, ill start my search.
  9. Nigel Goodwin
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    If you PM me your email address, I can send you the European manual - assuming your ISP allows large attachmanets.
  10. dirtyb15
    dirtyb15 Member
    Apr 8, 2005
    75
    0
    OHIO
    Thanks a bunch Nigel, i got the manual now. I have been going through the troubleshooting diagram, and the code does indicate backlight not lighting up.
    The next question is whether or not there is a control signal appearing at pin 2 and pin 3 of P7506 and P7616. Now, i measured these pins when I got the backlight to turn on, and pin 2 was 15 volts, and pin 3 was 4.4 volts. (on both P7506 and P7616)
    When the backlights dont turn on and i measure these pins i get 15 volts on both pin 2 and 3.
    Any ideas?
    I assume this means there is no control signal when the backlights are not on. If this is the case the manuals says to
    Check the circuits around IC4501
    in the main unit and check the
    operation of Q7704 and Q7705.
    I can check Q7704 and 7705, but what circuits should i be checking? Would there be something more prone to intermentent operation than total failure?
  11. Nigel Goodwin
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    Sorry, I've never seen one of those sets - but all LCD manual's seen pretty unhelpful in telling you what the feedback from the inverter is supposed to be.
    One thing you might try, is resistance measurements of all the transformers - apparently a common fault on many sets is transformers going O/C or high resistance - but personally, I've never seen one fail.
  12. Yetiman
    Yetiman New Member
    Jul 6, 2009
    1
    0
    Mendocino, Ca.
    Same Boat
    Hi Guys
    I was recently given the same model of Sharp 37" LCD in wont fire up condition, and came across your posts during my searches for info. It has fired up in the service mode (Vol- and Input held down while turning on the power) a number of times, but it is very hit or miss and stubbernly refusing lately. I've had the power supply pcb and the video/logic board out checking for cracked solder joints and cleaned all the connectors with Deoxit, but none of that helped. I'm going to order a bunch of those PC123 optoisolators and see if that makes a differance, but I am at the point were I really need a sckematic/service manual to figure out whats going on with it. Any chance one of you fine gents could sent a pdf my way? I would be ever so greatfull! Big files are Not a problem. Thanks a Bunch!
    Art
  13. unclejed613
    unclejed613 Well-Known Member
    Apr 3, 2009
    1,828
    99
    one thing that i've seen that causes backlight problems intermittantly is the high voltage wires from the inverters leaking to ground where they get pressed up next to the sheet metal. teflon tape around the pinch points seems to help, or you can take teflon plumbing tape and cut it into strips and lay the strips down overlapping and use clear packing tape to hold the teflon tape down to the sheet metal. teflon has a higher dielectric strength than black electrical tape. or you could paint the areas of sheet metal with corona dope.
  14. pacchu
    pacchu New Member
    Aug 23, 2009
    2
    0
    i too have an lg ly 95 42" lcd tv which when switched on works perfectly fine for a few minutes and then the the video flickers a few times and thereafter the video goes off whilst the audio is intact. i have been trying to find a solution for the problem, pse advise if anyone has a solution
  15. pacchu
    pacchu New Member
    Aug 23, 2009
    2
    0
    nigel i would be grateful if u have an idea as to what is the problem
  16. Nigel Goodwin
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    I would image it's most probably the backlights switching off?.
    Are the backlights still ON when the pictures goes?.
  17. jamoo
    jamoo New Member
    Jul 26, 2009
    1
    0
    nigeria
    how can i buy LG electronics part online
  18. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    This thread is about a SHARP LCD.
  19. sdmtidor
    sdmtidor New Member
    Mar 13, 2009
    1
    0
    Hell0.......... Good day to all............
    i need help for my IBM thinkpad loptop v5.......
    auto shot off.... need schematic diagram for the main board.........
  20. unclejed613
    Apr 3, 2009
    1,828
    99
    how many ways can we hijack a thread????????? read carefully...
    S-H-A-R-P L-C-D T-V
    if you still have a dark. but visible (under bright light) picture, it's the inverter board.
  21. MikeM
    MikeM New Member
    Sep 3, 2009
    3
    0
    Cheshire, UK
    Same Boat
    Hi Guys - first post, please be gentle.
    Yetiman,
    I have a Sharp LC37HV4E in for service which wouldn't come on until service mode was used. The menu stated error code 5 which I cleared. At the moment it's coming on from cold but I doubt very much that it's the cure.
    Did you end up changing the opto's and did it cure your problem?
    I too do not have a schematic, so may be in need of one.
    Many thanks in advance,
    MikeM
Share This Page
