    Dismiss Notice
Lcd 16x2 and Usb.Init ()
Discussion in 'AVR' started by mauros, Jun 18, 2017.
  1. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    The Usb.init () instruction creates problems with LCD display 16x2, depending on where I place it. When Usb.init is not present, the lcd shows anything but if Usb.init () is present, it happens that if for example i write before <lcd.print >
    lcd.print ("Hello World!")
    if (Usb.Init() == -1)
    {while(1);}
    "Hello World!" it is displayed on lcd
    but if i put <lcd.print > after
    {while(1);}
    lcd .print ("Hello World!")
    the lcd does not display anything.
    Thanks !!
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
    Whoops.... If USB == -1 then a forever loop... This is just the USB failing... Nothing wrong with the LCD code..
    Try this
    Code (c):
       lcd .print ("USB not found!!");
    else
         lcd .print ("USB up and running!!");
    {while(1);}
  3. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    I get that USB up and running. Being sure the USB was found, I tried to remove those two instructions and then it happens that the lcd display works but no longer runs the serial.
    Edit:
    I practically did not understand what those two instructions do
    ( I am replicating an existing project but i would like to modify it by adding the lcd display)
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
    Because after the USB init you go into a while(1) loop.. Nothing else can happen..
    Post the code!
  6. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    An android app created with MIT Inventor sends text to Arduino that must display it on the lcd display. I insert the most significant part of the code since there are more than 400 lines
    #include <LiquidCrystal.h>
    #include <Usb.h>
    #include <usbh_midi.h>
    LiquidCrystal lcd(10, 9, 8, 7, 6, 5);
    USB Usb;
    USBH_MIDI Midi(&Usb);
    String name;
    void setup()
    Serial.begin(115200); //start serial
    lcd.begin(16, 2);
    {while(1);}
    void loop() {
    if( Serial.available()) { //check for serial
    char ch = Serial.read(); //serial message
    if (ch == '~') { //song name starts after this
    name = ""; //empty the variable
    lcd.clear();
    for (int i=0; i<99; i++) { //counter to make sure you don't get stuck in an infinite loop
    char ch2 = Serial.read(); //read the serial, and store to ch2
    if (ch2 == '^') //last character of the transmission, so break
    break;
    else //otherwise, add the character to the song name
    name = name + ch2;
    Serial.println(name);
    lcd.print(name);
    Edit:
    Sorry I tried to insert the code independently of the message but I did not succeed
  7. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    Given that various data flow through the serial, to understand when the "name" passes, the protocol provides a start character and one end that says when "name" is finished
  8. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    To get an idea of the project, I replied what you see in the following video and i would like to add a display to show the title of the song sent from the tablet
  9. Ian Rogers
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
    Okay!! Your USB shield will need pin 10 as does you LCD.. You'll need to use another pin on the LCD.
  10. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    I did not think that pin 10 was used by the Usb Shield, I knew 11 and 12. The free digital pins I have are numbers 5,6,7,8,9,10,11,12,13. I tried with pin 13 and then with analog pin A5 defined as output (19) but the problem remains
  11. Ian Rogers
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
  12. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    Very restrictive :( No possibility under these conditions ?
    It seems that making a change to the library <UsbCore.h> i can use another pin (?)
  13. Ian Rogers
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
    Which boards are shields?? USB and LCD... If the LCD isn't on a shield you can use any pins... The LCDint allows you to specify alternate pins.
  14. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    Unfortunately, the LCD is connected to the USB shield which in turn is connected to Arduino. It could not be otherwise, except I did not understand what you mean
  15. Ian Rogers
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
    Have you a datasheet for this shield?? Is the LCD officially mounted to the USB shield or did you mount it??
  16. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
  17. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
    I bought this
    http://www.ebay.it/itm/322167092482
    Which would be the same as my display with the addition of the i2C module. So I should be able to use it with only 4 pins.
    Hoping to solve it
  18. Ian Rogers
    Mar 28, 2011
    8,932
    877
    Rochdale UK
    ONLINE
    Why don't you post a link to the USB module then I can see what you can do with the existing LCD..
    Otherwise you are going to need a library for I2C LCD
  19. mauros
    mauros New Member
    Apr 25, 2017
    24
    0
Share This Page
