    Dismiss Notice
Junebug PORTB header mod
Discussion in 'Microcontrollers' started by futz, Dec 12, 2007.
  1. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    After getting my LCD working on Junebug, I started thinking of ways to make it useful for something other than displaying the usual demo stuff. First thing I thought of was to display VR1 and VR2 values. Of course that's impossible because the LCD is using the RA1 and RA3 pins.
    It became obvious that it would be best if the LCD could move to PortB. I went over the board and schematic and realized that to get all the PortB pins to the LCD would mean a rat's nest of wiring. PortB is scattered all over the Junebug board, and RB0, 2 and 5 aren't brought out to a connector at all.
    So I thought to myself, "Self, wouldn't it be nice if PortB was pinned out all in one place? Hey! I think I'll do that!" :D
    So I added a PortB connector, bringing all the easily useful PortB pins (0 - 6) to it. Here's some pics of the project:
    Notes & prefabbed connector
    Prefabbed connector
    Bottom side
    Glue gun
    Bottom closeup
    Top side
    Top side closeup
    The hot-melt glue over the connector is just for extra insurance. The connector was squished into hot-melt and was nice and strong already.
    I made a minor mistake (thinking upside down) and built it with pin 0 on the left instead of where it should be, on the right. If I was to do it again I would fix that so the pin order corresponds to where the bits are in PORTB. Ah well, no big deal. Just plug it in upside down. :eek:
    Another thing I should have done was put 5V and ground on the connector. By the time I thought of it I was half done. Next time...
    Here's asm source for a quicky test program that just cycles thru the pins, turning each one on for 2 seconds and off for 2 seconds. Good for putting a meter on each pin to be sure you got it right. LED #1 lights when pin 0 is high.
    One gotcha is that you have to solder to the correct pin on the switches. Looking at the bottom of the board, only the right pin is connected.
    While using the header don't forget that the buttons will probably cause trouble if you push them while using the pins for something else. Your software and/or outboard hardware may not appreciate this.
    I haven't connected up my LCD and rewritten my code yet. Maybe tomorrow night.
  2. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    170
    Toronto, Canada
    Well you'll like the bigger PICs, the Unicorn PCB should be interesting as it's almost all I/O.
  3. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    I actually have quite a few bigger PICs. I just like messing around with the little ones. :D
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    Hehehe! Just now finished modding my LCD code to run on PORTB. Had some trouble getting it to go at first. I was trying to iorwf the values into LATB, but that wouldn't work for some reason. Tried iorwf'ing into PORTB. That didn't work. Finally realized that there was actually no reason to preserve the other bits and just switched to movwf and away she went!
    Tomorrow the VR1 and VR2, she gets displayed! :p
  6. 3v0
    3v0 Coop Build Coordinator Forum Supporter
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    You are to point where I would be adding a target board rather then make that many mods to the JuneBug. Not that you are wrong to do so.
  7. blueroomelectronics
    Jan 21, 2007
    12,536
    170
    Toronto, Canada
    Don't forget to make port B digital :) I forget that it has analog pins sometimes.
  8. UTMonkey
    UTMonkey New Member
    Oct 16, 2007
    450
    3
    Chesterfield, Derbyshire - UK
    I think I missed a trick when I ordered my JuneBug. I should have ordered the EasyLab at the same time.
  9. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    Heh. I've always modded my computers, right from the first ones I had (TRS-80 Color Computer and Model III). Microcontroller boards are no different. :D
  10. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    Done. It's all in ADCON1, right?
  11. blueroomelectronics
    Jan 21, 2007
    12,536
    170
    Toronto, Canada
    I'll have to get some stock of the BT-04 Cases, only places that sell them anywhere are the same places on my where to order page. They should be available on the Creatron Electronics eBay site soon.
    I know the LAB-EASY fellow and I think the cases are pretty neat for prototyping, cheaper than the Hammond 1591-B case my other kits use.
    http://www.blueroomelectronics.com/buynow.htm
    Edit: yep ADCON1 does the trick, no comparators to worry about on the 18F1320.
  12. UTMonkey
    UTMonkey New Member
    Oct 16, 2007
    450
    3
    Hope I am not stealing the thread here by asking this, what is a "Target Board"?
  13. UTMonkey
    UTMonkey New Member
    Oct 16, 2007
    450
    3
    Actually I have thought of another question, is there a connector that "clips" on top of the IC rather than having to solder connectors to the board.
  14. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    In the world of logic analyizers/emulators and processor probes the target board is the board under test. Although we are using an ICD we still refer to the users board as the target.
    There must be commerical clips for doing so. For dip chips you can make one by soldering wires to a DIP clip.
    [​IMG]
  15. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    Ya! I happy with that. :D
    Code (text):
        list    p=18F1320
        include <p18F1320.inc>
        CONFIG  OSC=INTIO2,WDT=OFF,MCLRE=ON,LVP=OFF
        cblock  0x00
            d1,d2,d3,dataout,temp,dec1,dec2,vr1,vr2
        endc
        org 0x0000
    init    bsf OSCCON,IRCF2    ;set to 8MHz clock
        bsf OSCCON,IRCF1
        bsf OSCCON,IRCF0
        movlw   b'00001010'
        movwf   TRISA
        clrf    TRISB
        clrf    LATA
        clrf    LATB
        call    dl_40ms     ;allow lcd to settle before init
        call    lcdinit     ;init lcd
        movlw   b'01110101' ;init a/d
        movwf   ADCON1
        movlw   b'00011101'
        movwf   ADCON2
    main    movlw   HIGH table1 ;display table1
        movwf   TBLPTRH
        movlw   LOW table1
        movwf   TBLPTRL
    oneloop tblrd   *+
        movf    TABLAT,W
        xorlw   0x00        ;zero?
        btfsc   STATUS,Z
        goto    print1      ;yes, done
        movwf   dataout     ;no, go again
        call    lcdchar
        goto    oneloop
    print1  call    analog
        movf    vr1,W
        call    fixhex
        movff   dec1,dataout
        call    lcdchar
        movff   dec2,dataout
        call    lcdchar
        call    lcd_line2
    linetwo movlw   HIGH table2 ;display table2
        movwf   TBLPTRH
        movlw   LOW table2
        movwf   TBLPTRL
    twoloop tblrd   *+
        movf    TABLAT,W
        xorlw   0x00        ;zero?
        btfsc   STATUS,Z
        goto    print2      ;yes, done
        call    lcdchar
        goto    twoloop
    print2  movf    vr2,W
        call    fixhex
        movff   dec1,dataout
        call    lcdchar
        movff   dec2,dataout
        call    lcdchar
        call    delay
        call    lcd_line1
        goto    main
    table1  db  "VR1 - $",0x00
    table2  db  "VR2 - $",0x00
    analog  movlw   b'00000101' ;enable a/d - an1
        movwf   ADCON0
        bsf ADCON0,GO   ;go do a/d conversion
    adloop  btfsc   ADCON0,DONE
        goto    adloop
        movff   ADRESH,vr1  ;store in vr1
        movlw   b'00001101' ;enable a/d - an3
        movwf   ADCON0
    adloop2 btfsc   ADCON0,DONE
        goto    adloop2
        movff   ADRESH,vr2  ;store in vr2
        return
    ; fixhex - subroutine takes byte passed in W - splits it into two
    ; ascii bytes representing hex digits and stores them in dec1/dec2
    fhex    db  "0","1","2","3","4","5","6","7","8","9","a","b","c","d","e","f"
    fixhex  movwf   temp        ;store it for later
        movwf   dec1        ;and put it in dec1 too
        movlw   0xf0        ;mask out low nybble
        andwf   dec1
        swapf   dec1,F      ;swap nybbles
        movlw   HIGH fhex   ;set up table pointer
        movwf   TBLPTRH
        movlw   LOW fhex
        movwf   TBLPTRL
        movf    dec1,W
        addwf   TBLPTRL     ;add offset
        btfsc   STATUS,C    ;was there a carry?
        incf    TBLPTRH,F   ;yes, increment table pointer MSB
        tblrd   *           ;read the byte
        movff   TABLAT,dec1 ;store it in dec1
    fixhx2  movlw   0x0f        ;mask out high nybble
        andwf   temp,F
        movwf   TBLPTRH
        movlw   LOW fhex
        movwf   TBLPTRL
        movf    temp,W
        movff   TABLAT,dec2
        return
    lcd_line1
        movlw   0x80
        movwf   dataout
        call    lcdcmd
        return
    lcd_line2
        movlw   0xc0
        movwf   dataout
        call    lcdcmd
        return
    lcdcmd  swapf   dataout,W   ;swap nybbles and transfer to w
        andlw   0x0f        ;mask out high nybble
        movwf   temp        ;rotate left 2 bits for B2-B5
        rlncf   temp,F
        rlncf   temp,W
        movwf   LATB        ;move to PORTB
        call    e_togg      ;latch the data
        movf    dataout,W   ;get byte in w again
        andlw   0x0f        ;and mask out high nybble
        movwf   temp        ;rotate data into position
        rlncf   temp,F
        rlncf   temp,W
        call    dl_50us
        return
    lcdchar swapf   dataout,W   ;swap nybbles and transfer to w
        rlncf   temp,F
        rlncf   temp,W
        bsf LATB,0      ;set RS high
        movf    dataout,w   ;get byte in w again
        rlncf   temp,F
        rlncf   temp,W
        bsf LATB,0      ;RS high
        call    dl_50us
        return
    e_togg  bsf LATB,1      ;toggle E to latch data
        nop         ;delay 450ns minimum
        nop
        nop
        bcf LATB,1
        return
    lcdinit movlw   b'00001100' ;send 03 nybble
        movwf   LATB
        call    e_togg
        call    dl_05ms     ;wait 5ms
        movlw   b'00001100' ;send 3 second time
        movwf   LATB
        call    e_togg
        call    dl_160us    ;wait 160us
        movlw   b'00001100' ;send 3 third time
        movwf   LATB
        call    e_togg
        movlw   b'00001000' ;enable 4-bit mode ($02 nybble)
        movwf   LATB
        call    e_togg
        call    dl_50us     ;wait 50us
        movlw   0x28        ;set 4-bit mode and 2-lines
        movwf   dataout
        call    lcdcmd
        movlw   0x10        ;cursor move & shift left
        movwf   dataout
        call    lcdcmd
        movlw   0x06        ;entry mode = increment
        movwf   dataout
        call    lcdcmd
        movlw   0x0d        ;display on, cursor on, blink on
        movwf   dataout
        call    lcdcmd
        movlw   0x01        ;clear display
        movwf   dataout
        call    lcdcmd
        return
    dl_40ms movlw   0x7e        ;40ms delay
        movwf   d1
        movlw   0x3f
        movwf   d2
    dl40_0  decfsz  d1,F
        goto    $+6
        decfsz  d2,F
        goto    dl40_0
        nop
        return
    dl_05ms movlw   0xce        ;5ms delay
        movwf   d1
        movlw   0x08
        movwf   d2
    dl05_0  decfsz  d1,F
        goto    $+6
        decfsz  d2,F
        goto    dl05_0
        return
    dl_160us            ;160us delay
        movlw   0x69
        movwf   d1
    dl160_0 decfsz  d1,F
        goto    dl160_0
        return
    dl_50us movlw   0x1f        ;50us delay
        movwf   d1
    dl50_0  decfsz  d1,F
        goto    dl50_0
        return
    delay   movlw   0x5e        ;.15 second delay
        movwf   d1
        movlw   0xeb
        movwf   d2
    delay_0 decfsz  d1,F
        goto    $+6
        decfsz  d2,F
        goto    delay_0
        return
        end
  16. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Unless I am routing power I use wire wrap wire for mods. The small diameter makes it easy to manage and it looks better. Much of the rework on commerical boards use it.
  17. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    Ya. That would be the best way to do it probably. I don't have any, so I used what I have. :)
    Being in construction (plumbing & heating), I often pick up scrap phone wire from jobsites. I have several dozen lifetimes supply of 22 or 24 gauge (whatever it is) copper wire. The insulation is too melty to make good jumpers (thus the heat shrink insulation), but it makes good breadboard wires.
  18. AtomSoft
    AtomSoft Well-Known Member
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Ok you all knew this was coming ... Thing is my own version of the portB mod but its a all pin mod. No junebug soldering. Simple to make. I havent made it in reality but i did it in 3d Studio Max. I hope you enjoy it!
    Board Layout: (basic layout, you can guess how this works really)
    Top Board and Bottom Board just make one bigger than the other and make the bottom 1 without the outer holes. So its only 2 rows on board 2:
    [​IMG]
    Some shots of it:
    Front:
    [​IMG]
    Side:
    [​IMG]
    Top:
    [​IMG]
    Angle:
    [​IMG]
  19. futz
    futz Active Member
    Sep 15, 2007
    2,043
    24
    Vancouver, B.C.
    That'll work. :D
  20. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    of course there are only 18 pins for junebug 18f1320 but this might be useful for other things also so ill leave it as a 2 x10 (20pin) Also i ordered a few sets of single row pin headers they should be here tuesday. When i make it ill take some pictures of course.
  21. Mike - K8LH
    Mike - K8LH Well-Known Member
    Jan 22, 2005
    3,642
    109
    Michigan, USA
    Have you considered simplifying the design a bit by using a machined pin socket with longer solder tail pins? This might allow for a single PCB in your adapter design.
    Mike
    [​IMG]
Share This Page
