Hackpenguin
heres my javascript library that contains a lot of functions and objects that can be used for electronic calculations.
heres a list of some of the stuff it can do
Source Code:
Wanna try it out visit **broken link removed**
- Ohms law
- Resistor Color code(4-band and 5-band resistors)
- Series and Parallel array of resistance,capacitance and inductance
- Reactance and resonance
- Voltage Dividers
- LED Resistor Calculator
Source Code:
jElectronics library v1.1 by Justin Roeder
Does electronic engineering calculations.
Website http://jelectronics.delphijustin.biz
var doctitle="";//title of the page before CreateHTMLCalculator was called
var LEDAmps=0;//Global variable for the Total LED Current
var registers= {x:jElectronics(),y:jElectronics(),R1:jElectronics(),R2:jElectronics()};//Registers for the HTML Calculator
var colors=new Array("Black","Brown","Red","Orange","Yellow","Green","Blue","Violet","Gray","White","Silver","Gold");//Resistor Color Code Array
function jElectronics(){//Object constructor function
return {Vf:0,Component:"Resistor",Volts:0,Amps:0,Ohms:0,Watts:0,Farads:0,Henries:0,Hertz:0,Rating:{Volts: 0,Amps:0,Ohms:0,Watts:0},
ResistorColor:{Four:{Band1:0,Band2:0,Band3:0,Str:function(){
return colors[this.Band1]+' '+colors[this.Band2]+' '+colors[this.Band3];
}},Five:{Band1:0,Band2:0,Band3:0,Band4:0,Str:function(){
return colors[this.Band1]+' '+colors[this.Band2]+' '+colors[this.Band3]+' '+colors[this.Band4];
UpdateResistorColor:function(){ObjectToResistorColor(this);},//Updates the resistor color code
UpdateReactance:function(){Reactance(this);},//Update the object with Reactance.
UpdateOhmsLaw:function(){OhmsLaw(this);},//Update the object with ohms law
UpdateResonant:function(){Resonant(this);},//Update the object with Resonance
SeriesOhms:function(a){this.Ohms=Series(a,'RESISTOR');},//Series resistance from a array of resistances
SeriesFarads:function(a){this.Farads=Series(a,'CAPACITOR');},//Series Capacitance from a array of capacitances
SeriesHenries:function(a){this.Henries=Series(a,'INDUCTOR');},//Series Inductance from a array of inductances
ParallelOhms:function(a){this.Ohms=Parallel(a,'RESISTOR');},//Parallel Resistance from a array of resistances
ParallelFarads:function(a){this.Farads=Parallel(a,'CAPACITOR');},//Parallel Capacitance from a array of capacitances
ParallelHenries:function(a){this.Henries=Parallel(a,'INDUCTOR');}//Parallel Inductance from a array of inductances
function ResistorMultiplier(c){//Library function,do not use
if(c==10){return 0.01;}
if(c==11){return 0.1;}
return Math.pow(10,c);
function OhmsLaw(obj){//does an ohms law update on the object returned from jElectronics() function
if(obj.Volts==0){obj.Volts=obj.Ohms*obj.Amps;}
if(obj.Amps==0){obj.Amps=obj.Volts/obj.Ohms;}
if(obj.Ohms==0){obj.Ohms=obj.Volts/obj.Amps;}
obj.Watts=obj.Volts*obj.Amps;
function Resonant(obj){//calculates resonances of a object
if(obj.Hertz==0){obj.Hertz=1/(2*Math.PI*Math.sqrt(obj.Farads*obj.Henries));}
if(obj.Henries==0){obj.Henries=1/(Math.pow(4*Math.PI,2)*Math.pow(obj.Hertz,2)*obj.Farads);}
if(obj.Farads==0){obj.Farads=1/(Math.pow(4*Math.PI,2)*Math.pow(obj.Hertz,2)*obj.Henries);}
function Series(x,ctype){//Series calculation of a array of values
var y=0;
for(z=0;z<x.length;z++){
switch(ctype.toUpperCase()){
case "CAPACITOR":y+= 1/(MetricPrefixToNumber(x[z]));break;
case "INDUCTOR":
case "RESISTOR":y+=MetricPrefixToNumber(x[z]);
if(ctype.toUpperCase()=="CAPACITOR"){return 1/y;}
return y;
function Parallel(x,ctype){//Calculates the parallel of an array of values
var y=0;
case "RESISTOR":
case "INDUCTOR":y+= 1/MetricPrefixToNumber(x[z]);break;
case "CAPACITOR":y+=MetricPrefixToNumber(x[z]);
if(ctype.toUpperCase()!="CAPACITOR"){return 1/y;}
return y;
function Reactance(obj){//Does reactance on the object,if Component is set to capacitor it will do capacitive reactance,if inductor then inductive reactanc,set to something else does nothing
if(obj.Component.toUpperCase()=="CAPACITOR"){
if(obj.Ohms==0){obj.Ohms=1/(2*Math.PI*obj.Hertz*obj.Farads);}
if(obj.Hertz==0){obj.Hertz=1/(2*Math.PI*obj.Ohms*obj.Farads);}
if(obj.Farads==0){obj.Farads=1/(2*Math.PI*obj.Ohms*obj.Hertz);}
} else {
if(obj.Component.toUpperCase()=="INDUCTOR"){
if(obj.Ohms==0){obj.Ohms=2*Math.PI*obj.Hertz*obj.Henries;}
if(obj.Hertz==0){obj.Hertz=obj.Ohms/(2*Math.PI*obj.Henries);}
if(obj.Henries==0){obj.Henries=obj.Ohms/(2*Math.PI*obj.Hertz);}
} else {return "?Invalid Component Type";}}
function LEDCalc(LED,PSU){//Calculates the LED Current from an object returned from jElectronics()
LED.Component="LED";
LED.Volts=PSU.Volts-LED.Vf;
OhmsLaw(LED);
function ObjectToResistorColor(obj){//Gets the Resistor Color Code from obj.Ohms
for(a=1;a<10;a++){
for(b=0;b<10;b++){
for(c=0;c<12;c++){
if(((a*10)+b)*ResistorMultiplier(c)==obj.Ohms){obj.ResistorColor.Four={Band1: a,Band2:b,Band3:c,Str:function(){
}};break;}
for(a=1;a<10;a++){
for(b=0;b<10;b++){
for(c=0;c<10;c++){
for(d=0;d<12;d++){
if(((a*100)+(b*10)+c)*ResistorMultiplier(d)==obj.Ohms){obj.ResistorColor.Five={Band1:a,Band2:b,Band3:c,Band4:d,Str:function(){
}};break;}
function UpdateWattage(obj,typ){//Updates the wattage,this is usually used by other functions in this library,the typ parameter is returned from jseDefineTypes function
if(typ.Volts&&typ.Amps){obj.Watts=obj.Volts*obj.Amps;}
if(typ.Amps&&typ.Ohms){obj.Watts=(obj.Amps*obj.Amps)*obj.Ohms;}
if(typ.Volts&&typ.Ohms){obj.Watts=(obj.Volts*obj.Volts)/obj.Ohms;}
function jseDefine(strFlags){//Defines which variables are to be used in the function by given string of flags.
var Flags=strFlags.toUpperCase();
return {Volts: (Flags.indexOf("V")>-1),Amps:(Flags.indexOf("A")>-1),Ohms: (Flags.indexOf("R")>-1)};
function VoltageDivide(R1,R2,VinObj){
R1 is the resistor 1 object
R2 is the resistor 2 object
Voltage Out on the R2.Volts
if(R2.Volts==0){R2.Volts=VinObj.Volts*(R2.Ohms/(R1.Ohms+R2.Ohms));}
if(VinObj.Volts==0){VinObj.Volts=(R2.Volts*((R1.Ohms+R2.Ohms)/R2.Ohms));}
if(R1.Ohms==0){R1.Ohms=-R2.Ohms+((R2.Ohms*VinObj.Volts)/R2.Volts);}
if(R2.Ohms==0){R2.Ohms=-((R2.Volts*R1.Ohms)/(R2.Volts-VinObj.Volts));}
R1.Volts=VinObj.Volts-R2.Volts;
var tmp=jElectronics();
tmp.Volts=VinObj.Volts;
tmp.Ohms=R1.Ohms;
OhmsLaw(tmp);
R1.Amps=tmp.Amps;
tmp.Ohms=R2.Ohms;
tmp.Amps=0;
OhmsLaw(tmp);
R2.Amps=tmp.Amps;
var RT=jElectronics();
RT.Ohms=R1.Ohms+R2.Ohms;
RT.Volts=VinObj.Volts;
OhmsLaw(RT);
return RT;
function UpdateResistorColor(obj,bands){
switch(bands){
case 4: obj.Ohms=(((obj.ResistorColor.Four.Band1*10)+Number(obj.ResistorColor.Four.Band2))*ResistorMultiplier(obj.ResistorColor.Four.Band3));
break;
case 5: obj.Ohms=((obj.ResistorColor.Five.Band1*100)+(obj.ResistorColor.Five.Band2*10)+Number(obj.ResistorColor.Five.Band3))*ResistorMultiplier(obj.ResistorColor.Five.Band4-1);
break;
ObjectToResistorColor(obj);
function UpdateResistorC(form,mode){//used for the html calculator
registers.x.ResistorColor.Four.Band1=form.c0.value;registers.x.ResistorColor.Five.Band1=form.c0.value;
registers.x.ResistorColor.Four.Band2=form.c1.value;registers.x.ResistorColor.Five.Band2=form.c1.value;
registers.x.ResistorColor.Four.Band3=form.c2.value;registers.x.ResistorColor.Five.Band3=form.c2.value;
registers.x.ResistorColor.Five.Band4=form.c3.value;
switch(mode){
case 1:
if(form.c0.value+form.c1.value+form.c2.value!=Math.abs(form.c0.value+form.c1.value+form.c2.value)){alert("The first 3 colors must be used");break;}
if(form.c3.value==-1){UpdateResistorColor(registers.x,4);}else{UpdateResistorColor(registers.x,5);}
form.r.value=NumberToMetricPrefix(registers.x.Ohms);
break;
case 0:registers.x.Ohms=MetricPrefixToNumber(form.r.value);
ObjectToResistorColor(registers.x);
document.getElementById("jeCalc").innerHTML+=form.r.value+' 4-band:'+colors[registers.x.ResistorColor.Four.Band1]+" "+colors[registers.x.ResistorColor.Four.Band2]+" "+colors[registers.x.ResistorColor.Four.Band3]+'<br>';
document.getElementById("jeCalc").innerHTML+=form.r.value+' 5-band:'+colors[registers.x.ResistorColor.Five.Band1]+" "+colors[registers.x.ResistorColor.Five.Band2]+" "+colors[registers.x.ResistorColor.Five.Band3]+" "+colors[registers.x.ResistorColor.Five.Band4]+'<br>';
function NumberToMetricPrefix(x){//Takes a number and formats it into a metric prefix string
if(x>=Math.pow(10,6)){return Number(x/Math.pow(10,6))+" M";}
if(x>=1000){return Number(x/1000)+" K";}
if(x>=1||x==0){return x+" ";};
if(x>=0.001){return Number(x/0.001)+" m";}
if(x>=Math.pow(10,-6)){return Number(x/Math.pow(10,-6))+" u";}
if(x>=Math.pow(10,-9)){return Number(x/Math.poe(10,-3))+" n";}
return Number(x/Math.pow(10,-12))+" p";
function MetricPrefixToNumber(sx){//Takes a metric prefix string and converts it to a number,make sure theres a space between the number and the metric prefix(example "1k" should be "1 k")
switch(sx.charAt(sx.length-1)){
case "k":
case "K":return parseFloat(sx)*1000;
case "M":return parseFloat(sx)*1000000;
case "m":return parseFloat(sx)*0.001;
case "U":
case "u":return parseFloat(sx)*Math.pow(10,-6);
case "n":
case "N":return parseFloat(sx)*Math.pow(10,-9);
case "p":
case "P":return parseFloat(sx)*Math.pow(10,-12);
if(!isNaN(parseFloat(sx))){return parseFloat(sx); } else {return 0;}
function SetComponentValue(obj,sx){
var x=MetricPrefixToNumber(sx);
switch(obj.Component.toUpperCase()){
case "RESISTOR":obj.Ohms=x;break;
case "CAPACITOR":obj.Farads=x;break;
case "INDUCTOR":obj.Henries=x;break;
function GetComponentValue(obj){
case "CAPACITOR":return {Value:parseFloat(NumberToMetricPrefix(obj.Farads)),Units:NumberToMetricPrefix(obj.Farads).slice(-1)+"Farads", ActualValue: obj.Farads};
case "RESISTOR":return {Value: parseFloat(NumberToMetricPrefix(obj.Ohms)),Units:NumberToMetricPrefix(obj.Ohms).slice(-1)+"Ohms",ActualValue: obj.Ohms};
case "INDUCTOR":return {Value: parseFloat(NumberToMetricPrefix(obj.Henries)),Units:NumberToMetricPrefix(obj.Henries).slice(-1)+"Henries",ActualValue: obj.Henries};
function SP(form){
if(form.design.value=="s"){form.x.value=NumberToMetricPrefix(Series(form.x.value.split(","),form.component.value));} else
{form.x.value=Number(Parallel(form.x.value.split(","),form.component.value));}
registers.x.Component=form.component.value;
registers.y.Component=form.component.value;
SetComponentValue(registers.x,form.x.value);
if(form.design.value=="s"){Series(registers.x,registers.y,form.bLast.checked);} else {
Parallel(registers.x,registers.y,form.bLast.checked);}
form.y.value=GetComponentValue(registers.y).Value+" "+GetComponentValue(registers.y).Units;
form.xa.value += GetComponentValue(registers.x).Value+" "+GetComponentValue(registers.x).Units+" "+form.design.value+'\r';
form.bLast.checked=false;
function HTMLReactance(form,mode){
registers.x.Ohms=MetricPrefixToNumber(form.ohms.value);
registers.x.Farads=MetricPrefixToNumber(form.farads.value);
registers.x.Henries=MetricPrefixToNumber(form.henries.value);
registers.x.Hertz=MetricPrefixToNumber(form.hertz.value);
registers.x.Volts=MetricPrefixToNumber(form.volts.value);
registers.x.Amps=MetricPrefixToNumber(form.amps.value);
if(mode==1){OhmsLaw(registers.x);}
if(mode==0){Reactance(registers.x);}
if(mode==2){Resonant(registers.x);}
form.hertz.value=NumberToMetricPrefix(registers.x.Hertz);
form.ohms.value=NumberToMetricPrefix(registers.x.Ohms);
form.farads.value=NumberToMetricPrefix(registers.x.Farads);
form.henries.value=NumberToMetricPrefix(registers.x.Henries);
form.volts.value=NumberToMetricPrefix(registers.x.Volts);
form.amps.value=NumberToMetricPrefix(registers.x.Amps);
function SetCalculatorMode(mode){
var s="";
LEDAmps=0;
registers.x=jElectronics();registers.y=jElectronics();registers.R1=jElectronics();registers.R2=jElectronics();
switch(mode){
case 0:
document.title='Menu - '+oldtitle;
document.getElementById("jeCalc").innerHTML='<input type="button" value="OhmsLaw" onclick="SetCalculatorMode(1)">'+
'<input type="button" value="Resistor Color Code" onclick="SetCalculatorMode(2)">'+
'<input type="button" value="Reactance" onclick="SetCalculatorMode(3)">'+
'<input type="button" value="Parallel/Series Combination" onclick="SetCalculatorMode(4)">'+
'<input type="button" value="Voltage Divider" onclick="SetCalculatorMode(5)">'+
'<input type="button" value="LED Resistor" onclick="SetCalculatorMode(6)">';break;
case 1:
document.title="Ohm's Law - "+oldtitle;
document.getElementById("jeCalc").innerHTML='<input type="text" name="volts" value="0">Volts<br>'+
'<input type="text" value="0" name="amps">Amps<br>'+
'<input type="text" value="0" name="ohms">Ohms<br>'+
'<input type="text" name="watts" readonly>Watts<br>'+
'<input type="button" value="Calculate" onclick="HTMLOhmsLaw(this.form)">';break;
case 2: document.title="Resistor Color Code - "+oldtitle;
document.getElementById("jeCalc").innerHTML='Resistor Value:<input type="text" name="r"><input type="button" value="Color From Resistance" onclick="UpdateResistorC(this.form,0)"><br>';
for(x=0;x<4;x++){
s+='<select name="c'+x+'">';
for(y=0;y<12;y++){
s+='<option value="'+y+'">'+colors[y]+'</option>';
s+='<option value="-1" selected>Not Used</option></select>';
document.getElementById("jeCalc").innerHTML+=s+'<input type="button" value="Resistance From Color" onclick="UpdateResistorC(this.form,1)"><p>';
break;
case 3: document.title="Reactance - "+oldtitle;
document.getElementById("jeCalc").innerHTML='Mode:<select name="component"><option value="capacitor" selected>Capacitive Reactance</option><option value="inductor">Inductive Reactance</option></select><br>'+
'Capacitance:<input type="text" name="farads" value="0"><br>'+
'Inductance:<input type="text" name="henries" value="0"><br><input type="button" value="Resonance" onclick="HTMLReactance(this.form,2)">'+
'Frequency:<input type="text" name="hertz" value="0"><br>'+
'Reactance:<input type="text" name="ohms" value="0"><input type="button" value="Calculate" onclick="HTMLReactance(this.form,0)"><br>'+
'AC Volts:<input type="text" name="volts" value="0"><br>'+
'Current:<input type="text" name="amps" value="0"><input type="button" value="Calulate with ohms law" onclick="HTMLReactance(this.form,1)">';
break;
case 4:
document.title="Series/Parallel Calculator - "+oldtitle;
document.getElementById("jeCalc").innerHTML='Component Values(Seperated by commas):<input type="text" name="x"><br>'+
'Type of component:<select name="component"><option value="resistor" selected>Resistor</option><option value="capacitor">Capacitor</option><option value="inductor">Inductor</option></select>'+
'Design:<select name="design"><option value="p">Parallel</option><option value="s" selected>Series</option><input type="button" value="Calculate" onclick="SP(this.form)"><br>';break;
case 5:
document.title="Voltage Divider - "+oldtitle;
document.getElementById("jeCalc").innerHTML='Voltage In:<input type="text" name="vin" value="0"><br>'+
'Voltage Out(voltage accross R2):<input type="text" name="vout" value="0"><br>'+
'R1 Resistance:<input type="text" name="r1" value="0"><br>'+
'R2 Resistance:<input type="text" name="r2" value="0"><br>'+
'R1 Voltage:<input type="text" name="r1v" value="0" readonly><br>'+
'Total Current:<input type="text" name="at" readonly>Max.Power:<input type="text" name="watts" readonly><br>'+
'<input type="button" value="Calculate" onclick="VD(this.form)"><br>'+
'<img src="http://subdiesel.files.wordpress.com/2011/06/voltagedivider1.png?w=500" width="256px" height="256px">';break;
case 6:document.title="LED Resistor - "+oldtitle;
document.getElementById("jeCalc").innerHTML='Current limiting resistor:<input type="text" name="r"><br>'+
'Voltage In:<input type="text" name="vin"><br>'+
'Forward Voltage Drop:<input type="text" name="vf"><br>'+
'Max. Current(in mA):<input type="number" name="amps" value="20"><input type="button" value="Add LED" onclick="AddLED(this.form)"><input type="button" value="Reset" onclick="SetCalculatorMode(6)"><br>'+
'<textarea name="list"></textarea>Total Current:<input type="text" name="it" readonly>';break;
default:alert("Feature not released yet!");return false;
document.getElementById("jeCalc").innerHTML+='<input type="button" value="Menu" onclick="SetCalculatorMode(0)">';
return true;
function AddLED(form){
registers.y.Volts=MetricPrefixToNumber(form.vin.value);
registers.x.Vf=MetricPrefixToNumber(form.vf.value);
registers.x.Amps=0.001*form.amps.value;
LEDCalc(registers.x,registers.y);
form.vin.value=NumberToMetricPrefix(registers.y.Volts);
form.vf.value=NumberToMetricPrefix(registers.x.Vf);
form.amps.value=registers.x.Amps/0.001;
LEDAmps+=registers.x.Amps;
form.it.value=NumberToMetricPrefix(LEDAmps);
form.list.value+='Vf:'+registers.x.Vf+',Ohms:'+NumberToMetricPrefix(registers.x.Ohms)+',If:'+Number(registers.x.Amps/0.001)+'\r';
function HTMLOhmsLaw(form){
if(parseFloat(form.volts.value)+parseFloat(form.amps.value)==0||parseFloat(form.ohms.value)+parseFloat(form.amps.value)==0||parseFloat(form.volts.value)+parseFloat(form.ohms.value)==0){
alert("There can only be one variable set to zero");
return false;
if(MetricPrefixToNumber(form.volts.value)*MetricPrefixToNumber(form.amps.value)*MetricPrefixToNumber(form.ohms.value)!=0){
alert("The variable your solving for must be set to zero first.");
return false;
var ol=jElectronics();
ol.Volts=MetricPrefixToNumber(form.volts.value);
ol.Ohms=MetricPrefixToNumber(form.ohms.value);
ol.Amps=MetricPrefixToNumber(form.amps.value);
OhmsLaw(ol);
form.volts.value=NumberToMetricPrefix(ol.Volts);
form.amps.value=NumberToMetricPrefix(ol.Amps);
form.ohms.value=NumberToMetricPrefix(ol.Ohms);
form.watts.value=NumberToMetricPrefix(ol.Watts);
function CreateHTMLCalculator(){//Call this up if you just want a easy already setup calculator with mode equal 0
oldtitle=document.title;
document.writeln('<form id="jeCalc" action="javascript:;">Loading...</form>');
document.writeln('<div id="jeStatus"></div>');
setTimeout("SetCalculatorMode(0)",5000);
function VD(form){
registers.R1.Volts=MetricPrefixToNumber(form.r1v.value);
registers.R1.Ohms=MetricPrefixToNumber(form.r1.value);
registers.R2.Ohms=MetricPrefixToNumber(form.r2.value);
registers.R2.Volts=MetricPrefixToNumber(form.vout.value);
registers.x.Volts=MetricPrefixToNumber(form.vin.value);
registers.y=VoltageDivide(registers.R1,registers.R2,registers.x);
form.at.value=NumberToMetricPrefix(registers.y.Amps);
form.watts.value=NumberToMetricPrefix(registers.y.Watts);
form.r1v.value=NumberToMetricPrefix(registers.R1.Volts);
form.r1.value=NumberToMetricPrefix(registers.R1.Ohms);
form.r2.value=NumberToMetricPrefix(registers.R2.Ohms);
form.vout.value=NumberToMetricPrefix(registers.R2.Volts);
form.vin.value=NumberToMetricPrefix(registers.x.Volts);
function isSafeOperating(obj){
checks component objects rating to see if its at a safe operating level
Is Safe returns 0
otherwise the Return value is a combination of the following values
Too much voltage 1
Too much current 2
Too much wattage 4
Too low resistance 8
To check for an overload you can do a bitwise AND against it.
example:
if(isSafeOperating(obj)&4>0){document.writeln("Too much wattage");}
var Overloads=0;
if(obj.Rating.Volts>0){if(Math.abs(obj.Volts)>obj.Rating.Volts){Overloads=1;}}
if(obj.Rating.Amps>0){if(Math.abs(obj.Amps)>obj.Rating.Volts){Overloads +=2;}}
if(obj.Rating.Watts>0){if(Math.abs(obj.Watts)>obj.Rating.Watts){Overloads+=4;}}
if(obj.Rating.Ohms>0){if(Math.abs(obj.Ohms)<obj.Rating.Ohms){Overloads+=8;}}
return Overloads;
