ok, i have 6,600microfarad capacitor i have seen that if i short it, multimeter shows 0v and slowly-2 it reading increases to 1 volt max. pls tell why this happen in capacitor charge by surrounding.
If your meter does not read AC current then buy a meter that reads AC current.ok, tell how to find Transformer ac current output with this multimeter..?
I can also find current with rating, but i was asking without rating how to calculate it, as there is a relation of RMS = Vmax./1.41 for the voltage , when i connect rectifier on it's terminal the output current is 7amp. is there any relation to find it's RMS current.
That 1.414 Figure is ONLY For TRUE SINE WAVE.
Your Inverter is NOT True Sine Wave, It is Most Likely SQUARE WAVE.
You Could take the Transformer Apart and See What Size of wires are on the Primary and Secondary.
Than Based on a Reasonable Value of about 700 Circular Mils per Inch, You could Calculate a Typical Current rating.
(A Circular Mil is 1/1000 of an inch.)
And are you ONLY interested in the Transformer Spec's?
Or the Actual Output of the Inverter?
If for the Inverter, There are other things to Consider:
Is this transformer Wound Correctly for an Inverter Circuit?
EXAMPLE: The Primary Winding NEED to be Bifilar Wound, For Maximum Efficiency.
its will be useless if you keep trying to learn the WHOLE from internetsir, from where this 1.313 constant value you have taken from, and in ltspice software to make transformer circuit it ask how much impedance of sec. and primary coil , pls tell relation between no. of turn's and impedance.
