2PAC Mafia
Hi guys,
sometimes when I had to repair some device based in inverter design, 300V or 400V PFC DC power changed to 220 or 380 Vac power, always at the end stage we find a power IGBT module. For troubleshooting can be necessary to disconnect the load (as a Vac electric motor) but I´ve seen usually at devices or documentation an advice saying "Don´t connect main power without load, IGBT can be damaged".
I would like to test the output and see the waveform without load and I would like to get an explanation why IGBT can be damaged if it works without load connected. The signal at gate should be the same and without load connected IGBT shouldn´t drain amps...
This is to test that IGBT works properly isolating the load stage.
