Interfacing eeprom with 89c51
silaj86
hi
i want to interface 89c51 with eeprom and save the data in eeprom from 89c51. can antbody helps me???
ineed code
Regards
Faizan
hi
here is the code in c
include<intrins.h> //For using [_nop_()]
sbit sda=P1^0;
sbit scl=P1^1;
sbit led=P0^3;
bit ack;
sbit led1=P0^1;
sfr lcd_data_pin=0xA0;//p2 port
sfr output=0x80;//p0 port
sbit rs=P3^0;
sbit rw=P3^1;
sbit en=P3^6;
unsigned char reead,write,write2,i,j;
unsigned int temp;
void delay(unsigned int count)
int i,j;
for(i=0;i<count;i++)
for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(1);
en=0;
void lcd_data(unsigned char disp)
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(1);
en=0;
lcd_dataa(unsigned char *disp)
int x;
for(x=0;disp[x]!=0;x++)
lcd_data(disp[x]);
void lcd_ini()
lcd_command(0x38); // for using 8-bit 2 row LCD
delay(5);
lcd_command(0x0F); // for display on, cursor blinking
delay(5);
lcd_command(0x80);
delay(5);
void aknowledge() //acknowledge condition
scl=1;
_nop_();
_nop_();
scl=0;
void start() //start condition
sda=1;
scl=1;
_nop_(); //No operation
_nop_();
sda=0;
scl=0;
void stop() //stop condition
sda=0;
scl=1;
_nop_();
_nop_();
sda=1;
scl=0;
void send_byte(unsigned char value) //send byte serially
unsigned int i;
unsigned char send;
send=value;
for(i=0;i<8;i++)
sda=send/128; //extracting MSB
send=send<<1; //shiftng left
scl=1;
_nop_();
_nop_();
scl=0;
ack=sda; //reading acknowledge
sda=0;
unsigned char read_byte() //reading from EEPROM serially
unsigned int i;
sda=1;
reead=0;
for(i=0;i<8;i++)
reead=reead<<1;
scl=1;
_nop_();
_nop_();
if(sda==1)
reead++;
scl=0;
sda=0;
return reead; //Returns 8 bit data here
void save() //save in EEPROM
start();
send_byte(0xA0); //device address
aknowledge();
send_byte(0x00); //word address
aknowledge();
send_byte(5); //send data
aknowledge();
send_byte(65);
aknowledge();
stop();
if(ack==0)
led1=1;
delay(100);
led1=0;
delay(100);
lcd_command(0x86);
lcd_data('5');
lcd_command(0x87);
lcd_data('A');
else
led1=1;
aknowledge();
void Read()
start();
send_byte(0xA0);
aknowledge();
send_byte(0x00);
aknowledge();
start();
send_byte(0xA1); //device address
aknowledge();
i=read_byte();
aknowledge();
j=read_byte();
aknowledge();
stop();
if(i==5)
led=0;
delay(100);
led=1;
delay(100);
write=i+48;
lcd_command(0xC6);
lcd_data(write);
else
led=1;
if(j==65)
lcd_command(0xC7);
lcd_data(j);
aknowledge();
void main()
lcd_ini();
lcd_dataa("Sent :");
lcd_command(0xC0);
lcd_dataa("Read :");
temp=0;
while(1)
save();
Read();
visit serial **broken link removed** or 8051 projects for more 8051 based projects
Hello...
i have utilized the same code.... how do i store data like "19:29:23" in EEPROM and how do i read it from EEPROM. because the code u have specified above has a control over one character at a time.....
