Instruction set
Parth86
I want to learn basic Idea that how dose Instruction set Implement
look at following handy example
8 bit Instruction set
first 4 bit for Alu function
last 4 bit for register
A=address register 4bit
I=instruction register 4bit
R1= register 4 bit
R2= register 4 bit
alu function               AIR1R2
ALU_NOP 4'b0000            XXXX
ALU_ADD 4'b0001             XXXX
ALU_SUB 4'b0010              XXXX
ALU_MUL 4'b0011             XXXX
ALU_DIV 4'b0100              XXXX
ALU_DA 4'b0101               XXXX
ALU_NOT 4'b0110             XXXX
ALU_AND 4'b0111            XXXX
ALU_XOR 4'b1000             XXXX
ALU_OR 4'b1001             XXXX
ALU_RL 4'b1010             XXXX
ALU_RLC 4'b1011            XXXX
ALU_RR 4'b1100              XXXX
ALU_RRC 4'b1101            XXXX
ALU_INC 4'b1110             XXXX
ALU_XCH 4'b111               XXXX
and If ALU_OR 4'b1001
AIR1R2                        alu out
0000                                     0
0001                                      1
0010                                      1
0011                                      1
0000                                      0
0001                                      1
0010                                      1
0011                                      1
0000                                      0
0001                                      1
0010                                      1
0011                                      1
0000                                      0
0001                                      1
0010                                      1
0011                                      1
If ALU_AND 4'b0111
AIR1R2                  alu out
0000                                     0
0001                                      0
0010                                      0
0011                                     1
0000                                      0
0001                                      0
0010                                      0
0011                                     1
0000                                      0
0001                                      0
0010                                      0
0011                                      1
0000                                     0
0001                                      0
0010                                      0
0011                                      1
I made above example just for learning
