    Dismiss Notice
Inductor and Solar Power
Discussion in 'Alternative Energy' started by martianman, Sep 27, 2009.
  1. martianman
    martianman New Member
    Dec 22, 2008
    8
    0
    Hi all,
    I'm redoing an entire room in my house and I don't want to use any more power. How can I use inductors/solar power/wind/capacitors/inverters and that shake flashlight idea to make the most efficient way to power this room? I'm not totally in the best spot for sun or wind unfortunately so that's going to be a hindrance. I don't want to use any battery power. I want to use renewable energy that will last, at least in theory, forever. (Or a very long time... whichever). I want to have at least 3-6 wall outlets plus I want to power some very low voltage LED lamps that I'm building. (Around 5 volts) I'd love to hear any suggestions. The best would be if someone could think of a way to combine all these things together... I'd also love some circuit diagrams too if possible.
    Thanks in advance,
    -Martianman
  2. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Does the rest of your house use energy efficient light bulbs?
  3. martianman
    Dec 22, 2008
    8
    0
    Yes. But I want to use alternative energy for this room. It's a good project for me. I would eventually like to make the rest of my house use alternative energy. But right now I just want to do it with one room to see how it works out. :)
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Solar or wind power plus a grid tie inverter. Not cheap mind you. You'll need to estimate the power requirements for the room.
  6. martianman
    Dec 22, 2008
    8
    0
    Ok so how do I do this? Could you provide a circuit diagram. If so, that would be great! :)
  7. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
  8. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    You have to import energy into the room somehow. Solar and wind are out?
    Shake flashlights aren't a great source of electricity, unless you really have stamina. The bigger ones can produce almost a quarter watt once you get them going. Mine uses a NiMH battery to store the power till I need it. Figure 200 shakers to run a small 50 watt television (100 people). Is it a small room?
    I've seen bicycles and treadmills hooked up to generators. They claim up to 100 watts if you're iin good shape. But that's hardly enough to supply one outlet, let alone 4 or 5.
  9. martianman
    Dec 22, 2008
    8
    0
    I wasn't thinking people power for the shake flashlight idea. I was thinking more like magnets somehow powering it... though I can't figure out how to do that...
  10. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    Contrary to what you may have read, magnets are NOT an energy source. A magnet at rest has no power to offer. If you apply WORK to a magnet, then a coil near by can pick up some power. That's why you need to shake the flashlight.
  11. martianman
    Dec 22, 2008
    8
    0
    I am aware that magnets are not a source of power. I was thinking of applying some sort of force to two magnets on opposite sides of the magnet in the middle of the coil so the magnets would continuously repel the magnet in the middle thereby forcing it to move back and forth...
  12. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    As you extract energy from a moving object it will slow down or stop. To keep it moving you must perform work on it.
    To keep producing power without doing work on the system is a classical Perpetual Motion machine which has already been invented many times.
  13. Thunderchild
    Thunderchild New Member
    Jul 3, 2005
    2,294
    9
    UK
    I hate to dapen your enthusiasm but what planet did you say you com from again ? you appear to have no technical knowledge and are hoping for a miracle/dream come true !, what exactly are you going to do with inductors ?
Share This Page
