    Dismiss Notice
Incorrect digit display in 7-segments by using PIC
Discussion in 'Microcontrollers' started by cxiong, Apr 14, 2003.
  1. cxiong
    cxiong New Member
    Apr 14, 2003
    1
    0
    Georgia
    I have tried to use the PIC16F877 to work as a temperature display
    device.
    I used a thermo sensor from radioshack. I used PORTA RA0/AN0 to do
    the ADC and used PORTD as output and connected it to all segments abcdefg (3 modules), and used
    PORTE as output - RE0 - RE2 as control signals to 3 modules (common cathode)
    through 3 transistors.
    The problem I have is that I can not display all 3 display at
    the same time. Because when all 3 display are used, I have to set
    PORTE,0,1,2 to a high state. Example, I want to display 100, (module2=1 , module1=0, &
    module0=0). What I get are all 3 modules display
    000 because all the data abcdefg of all segments connected together.
    What should I do to display the right number in each individual
    segment?
    Please help.
    Thanks...
  2. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    Can you post up the asm listing ?
  3. Pilot
    Pilot New Member
    Jan 5, 2003
    191
    0
    England
    Not being into pic programming - yet - the only way I see the problem is...
    PORTE, RE0 - RE2, need to be high so the segments light. I would forget this idea and just wire the led's as normal.
    As the 3 led's are connected in parallel whatever you write to one will display on ALL - as long as PORTE is high so...
    Use a latching circuit on each led and use PORTE to control the latch.
    This allows you to parallel the lines from pic to latch but beyond this they must be seperate.
    Write to PORTD, set RE2 high, write to PORTD, set RE1 high, write to PORTD, set RE0 high.
    Result, if I've not drunk too much, is that each led will display what you want.
    There may be a better solution but it's too late at night & I don't program pics.
    Must go, more beer has arrived.
    :lol: :lol:
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. KDog
    KDog New Member
    May 7, 2003
    1
    0
    ACT
    Yeah that's what you need to do.
    Basically you just turn on each display for one third of the time. When that display is on it displays its data. so for 100 you might have.
    E0=high (to turn on this segment display)
    PortD=data to display 1
    E0=low (to turn off display segment)
    E1=high
    PortD=data to display a 0
    E1=low
    E2=high
    E2=low.
    It will cycle through so quickly it will appear as though the displays are on all the time. The only downside is that you loose a bit of brightness because the displays aren't actually on all the time.
  6. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Have you connected transistor at the outout of port E or you have directly connected it to supply pin of display?
    If you haven't used the transistor, then it will create a problem since port pin cannot supply current to lit 7 LEDs.
    And one more thing, in multiplexed displays LEDs are drvien at a current highr than the rated to make display brightnees comparable to non-multiplexed displays. So you need much higher current from port to drive it which can be only taken from Vcc line using a transistor.
  7. Stardus
    Stardus New Member
    May 20, 2003
    5
    0
    Belgium
Share This Page
