improve voltage/current of a square wave signal
Daring
If i have a square wave signal (10->100hz) from a signal generating source,
is there a simple way to improve the Power of it (Voltage and/or current) with an external circuit?
something like :
starting from a signal like : 0 -> 5v or -2v -> 2v and with simple, easy to find, not too expensise comps
boost the amplitude to 0->10v or -5 -> -5v (which will probably be depending on your external power supply)
but also allow more current to be drained (instead of lets say 20mA 100mA or even more)
i have some transformers from electrical devices that may work as a power source (DC 12V/1A)
its been a while for me and electronics but i think an opamp may do the voltage boost first followed by some current boost circuit.
any suggestions are appreciated.
something like :
Hi Daring,
Off the top of my head:
(1) 0V to 10V at 20mA would be fairly easy (15V @ 500mA power supply required)
(2) 0V to 10V at 100mA would be relatively straight forward (15V at 1A power supply required
(3) -5V to +5V at 20mA not too bad (+12V at 500mA and -12V at 500mA power supplies required)
(4) -5V to +5V at 100mA more difficult (+12V at 1A and -12V at 1A power supplies required)
(5) You have not asked this but, -10 to +10 at 100mA, doable (+15V at 1A and -15V at 1A power suppies required)
To give you an idea of costs, take option (5) above:
(1) 15V at 1A power supply x2: $20US total
(2) Case and mechanical parts: $20US
(3) Electronic parts: $20US
spec
I used the LT1010 in the topology (trapezoidal waves) used in "Isolating Capacitive Loads". The OP-amp choice isn't critical. The circuit described is Unity gain.
You would likely need dual supplies.
