    Dismiss Notice
I/O mapped I/O question
Discussion in '8051/8951' started by rameshrai, Dec 10, 2014.
  1. rameshrai
    rameshrai Member
    Aug 8, 2010
    85
    0
    garden
    can RAM or ROM memory be addressed using I/O mapped I/O?
    thanks
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    On a 8051 RAM and ROM can be external and internal... So yes!
  3. rameshrai
    rameshrai Member
    Aug 8, 2010
    85
    0
    garden
    if one has both option(memory mapped I/O and I/O mapped I/O) to access RAM/ROM why memory mapped I/O? why not I/O mapped I/O?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    I don't really understand "I/O mapped memory"
    1) There is internal memory and external memory. Simply memory can be inside the IC or in another external IC.
    2)There is CODE memory which can be read but not written and normally contains instructions. AND Data memory (RAM memory) that normally holds data.
    That describes 4 types of memory.
  6. rameshrai
    rameshrai Member
    Aug 8, 2010
    85
    0
    garden
    hi RON, that really doesn't answer my second question,
    "if one has both option(memory mapped I/O and I/O mapped I/O) to access RAM/ROM why memory mapped I/O? why not I/O mapped I/O? "
    what do you mean by I/O mapped memory? do you mean memory mapped I/O?
  7. ronsimpson
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    I think I/O is done through special function registers. There is only a small numbers of those available.
    There are 64k of memory locations.
  8. Ian Rogers
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    If we are talking about the intel..... Then mapped I/O refers to address space..... I'll explain...
    On most micro controllers ports, modules and peripherals are set in stone... Each has several address in memory SFR's ( RAM) that controls their actions.. The Intel micro also has SFR's for the basic stuff.. BUT! can also have mapped I/O... If you place an LCD at some arbitrary address.. ie.. 0xA000... You can read and write to that address, the same as you would if it were an SFR...
  9. rameshrai
    rameshrai Member
    Aug 8, 2010
    85
    0
    garden
    hi Ian,
    thanks for your reply
    but the question why I/O mapped I/O not used for RAM? for example in case of 8085
  10. rameshrai
    rameshrai Member
    Aug 8, 2010
    85
    0
    garden
    in I/O mapped I/O using 8085 only 8 address lines may be used, it says but why only 8 bits?
  11. Ian Rogers
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    The old 6502 and the old ZX80 used to have 255 memory mapped I/O addresses.... Just the way it was designed..
    I suppose at the time of design the designers didn't expect to connect so many devices to the processor...
  12. ronsimpson
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    I think on the 8051 a 8 bit address is faster than a 16 bit address. When I look at the number of clocks it takes to address something.
  13. Jon Wilder
    Jon Wilder Active Member
    Oct 22, 2010
    859
    82
    Fresno, CA
    By memory mapped I/O, are we referring to the ability to use hardware buffers and gates to hard lock a piece of hardware interfaced to the 8051's FSB to a RAM memory address or address block, then read/write on that piece of hardware via use of the movx instruction?
Share This Page
