    Dismiss Notice
Hydroelectric power generation
Discussion in 'Alternative Energy' started by Techie7, Dec 12, 2008.
  1. Techie7
    Techie7 Member
    Nov 29, 2008
    106
    3
    Hope you experts will help me regarding this.
    In a hydroelectric project water stored in a reservoir pumps to upper hill tank from there rooted to down powerstation through penstockes. I couldn't understand the efficiency of this system. my question is:
    Energy used for pumping lower level water to higher level.
    Energy generated from taking the higher level water to lower level powestation.
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,199
    640
    Derbyshire, UK
    What's to understand? - efficiency is fairly low - but it's used to store energy during low power consumption periods, where the electricity would be 'wasted' otherwise.
    Then, during sudden peak demand, the water can be released and very quickly generate multi-megawatts.
    There's a classic example in Wales near Snowden - the power station is built entirely in a mountain, and pumps water to a lake at the top. It's a tourist attraction, you go in on a coach - it's really pretty cool.
  3. Techie7
    Techie7 Member
    Nov 29, 2008
    106
    3
    so you mean when some power is generated, it should be fully utilized anyway?
    y can't turn off some of the generators when low consumption time and save that wasting of energy.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Nigel Goodwin
    Nov 17, 2003
    39,199
    640
    Derbyshire, UK
    There's a point that generators run at where they are most efficient, it makes sense to run them at that level as much as you can - bear in mind you can't stop and start normal power stations in a few minutes. Even the stored power station takes time - although by powering the alternators from the grid (which takes megawatts to do) it can go to full power in a few seconds.
    Have a read about Dinorwig
    First Hydro Electric Mountain Llanberis
    Even if you did turn off power stations during low demand, where are you going to get the sudden high peak demand you might need?.
  6. Techie7
    Techie7 Member
    Nov 29, 2008
    106
    3
    but is that applicable to both cases ryt? for not wasting the energy, we start up a storage pump at low demand hours. When a sudden peak demand comes then we have to turn off that pump because the sudden peak demands the energy used by the storage pump :confused:
  7. Diver300
    Diver300 Well-Known Member
    Oct 19, 2007
    3,062
    101
    England
    Yes. If the pump is being used to pump water uphill when there is surplus electricity, it can be shut off in seconds if there is a sudden surge in demand.
    The ability to go from 1.3 GW load to 1.3GW of generation in a few seconds is quite neat.
    First Hydro Dinorwig Power Station has some interesting facts and figures. They suggest that the station efficiency is about 75%. That is the total from electricity to rotation to water flow to potential energy to water flow to rotation to electricity.
    That's not bad compared to the approx 60% efficiency of a car alternator and it only goes from rotation to electricity.
  8. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    Don't they use the alternators as motors?
    A car alternator is inefficient because it's small (the efficiency of motors and alternators goes up with size) and designed to work at a large range of speeds.
  9. Techie7
    Techie7 Member
    Nov 29, 2008
    106
    3
    Thanks very much guys.....
  10. KMoffett
    KMoffett Well-Known Member
    Oct 5, 2007
    2,496
    58
    Minnesota, USA
    Also think of combining wind or solar power generation with the lake as a way of storing their energy in non-peak demand periods.
    Ken
  11. Nigel Goodwin
    Nov 17, 2003
    39,199
    640
    Derbyshire, UK
    It's automatic - such sources just feed the grid, if there's surplus on the grid they use it to pump water.
  12. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    Yeah, I remember when I was in junior high (or was it high school?) and was shocked to learn that they didn't shut down some of the generators during the night because it took too long to start them back up again (like ~10 hours or so?) so they were just left running the entire night doing very little.
  13. danielsmusic
    danielsmusic New Member
    Jul 24, 2005
    458
    0
    cheshire
    You can compare the lake at the top as one gigantic uber capacitor.
  14. Nigel Goodwin
    Nov 17, 2003
    39,199
    640
    Derbyshire, UK
    Not really, the lake at the top is like one plate of a capacitor, the lake at the bottom is the other plate.
Share This Page
