    Dismiss Notice
HT12D and HT12E encoder/decoder issues
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by MrDEB, Dec 4, 2012.
  1. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,792
    134
    morristown,tn
    This
    Code (text):
     While true
         portb.0 = 1
          Delayms(50)
         Portb.0 = 0
          delayms(50)
     Wend
    used the same as this
    Code (text):
    While true
          DelayMS(50)
         toggle(portb.0)
          DelayMS(50)
     Wend
    Now that was done with the full ver's of Swordfish Basic the free is not as good toggle uses more with it.
  2. JonSea
    JonSea Well-Known Member
    Oct 1, 2012
    1,118
    90
    Seattle, WA
    True Burt. But MrDEB isn't using TOGGLE in a loop...he's using it ONE TIME to turn on an LED. This is a big waste of resources.
  3. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    The INTERRUPT on portB was an example that Graham used. It seems to do what it is supposed to do seeing how I need to wake up each time a tilt switch is closed.
    Working on a different issue. Wondering if I really need the weak pullups on portB but it works BUT on portB.6 I show 1.46v while portB.4&5 show 3.75. (I have 10k pullups soldered in the circuit.)
    Another issue I need to look at is Grahams code used switches on PortC to interrupt on PortB but this shouldn't make to much difference?
    In the mean time having fits with the tilt switches. The damped ones work well, One works really well while the other one is really slow. Experimenting with the dampened and undampened switches. Shaking and pounding on the bench etc. Seem pretty resilient to shaking etc but ?
    As far as TOGGLE, only using for testing (indication) not going in the final code but yes I wondered about too much in the INTERRUPT?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    Going to attempt to get the interrupt with less code within.
  6. JonSea
    Oct 1, 2012
    1,118
    90
    Seattle, WA
    Whether or not it's going in the final code is no reason NOT to understand how it should be used and why it's undesirable to use it when not needed.
    If you're asking if you need weak pullups enabled and you have 10K pullup resistors installed, the answer is no. If you are wondering if you need pullups at all, further discussion is not worthwhile.
    A command or two is reasonable. More may lead to problems and unreliable operations. The usual approach is set a flag and get out.
    The code in the interrupt routine might be:
    ButtonPressed = True
    Elsewhere in the code....like the first thing in the program loop...is a routine to read which button is pressed and take appropriate action.
  7. be80be
    Aug 23, 2008
    4,792
    134
    morristown,tn
    This is grams code for interrupt's on portb I don't think yours look any thing like this
    Code (text):
    Interrupt PORTB_Change()
     Save(0) // Save the system variables
     If RBIF = 1 Then // Check if the interrupt was a PORTB change
     RBIF = 0
     WREG = PORTB // Be sure to read the contents of PORTB to
     // clear the mismatch
     // PORTB 7:4 has changed, do what you want here...
     PORTC = PORTB // In this case, I am making PORTC = PORTB
     EndIf
     Restore // Restore the system variables
    End Interrupt
  8. be80be
    Aug 23, 2008
    4,792
    134
    morristown,tn
    See this part you would change to do what needs done
    Code (text):
     PORTC = PORTB
     EndIf
    End Interrupt
    First off you should of tried this code as is and looked how it worked.
    Then you could of wrote some thing like this
    Code (text):
    Dim SavePort as byte
     SavePort = PORTB  // In this case, I am saving to a variable to test in main
    // so the chip can keep doing something useful and not a have a melt down becuse I got lost in
    // a long interupt hander becuse you don't no that your code jumps to the wrong place.
     EndIf
    End Interrupt
    main:
     If saveport = XX then // I had a button press
      // do this
      High(portc.0)
    else
     Low(portc.0)
    endif
  9. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    I realize I need the port pins pulled high, I was worried WHY the portb.6 was lower than the rest of the port pins.
    Going to rewrite my code tomorrow and my code has all the elements that Graham has in his code except portC = portB. This is where I think I made my big mistake.
    Going to bed an mull over the issues. Tomorrow is a new day so I will start fresh.
    YES I should have tried out Grahams code but read through it and get the drift of what and why except the PORTC = PORTB.
    I like what Burt posted for code suggestion. Will give it a whirll in the morning
    Nite All
  10. JonSea
    Oct 1, 2012
    1,118
    90
    Seattle, WA
    Please READ Graham's code. Here it is again.
    Code (text):
     RBIF = 0
     EndIf
    End Interrupt
    Ok. Count.
    Step 1: Save(0)
    Step 2: If RBIF = 1 Then
    RBIF = 0
    WREG = PORTB
    PORTC = PORTB
    EndIf
    Step 3: Restore
    End Interrupt
    Let's set. Save the context. One command. One IF/THEN statement. Two commands. Restore the context. Three commands. SHORT. FEW COMMANDS. The absolute minimum possible.
    PORTC = PORTB has absolutely NOTHING to do with what you are trying to do - it's only there as an EXAMPLE. DO NOT PUT THIS IN YOUR CODE.
    Now, guess what? Leave out PORTC = PORTB. Instead, put in WhatTheHellButtonWasPressed = PORTB. Then test WhatTheHellButtonWasPressed in the main program loop to determine which button caused the interrupt.
    Code (text):
    If WhatTheHellButtonWasPressed.bits(4) = 1 then
          'the button connected to RB4 was pressed
    End if
    If WhatTheHellButtonWasPressed.bits(5) = 1 then
          'the button connected to RB5 was pressed
    End if
    If WhatTheHellButtonWasPressed.bits(6) = 1 then
          'the button connected to RB6 was pressed
    End if
    If WhatTheHellButtonWasPressed.bits(47) = 1 then
          'the button connected to RB7 was pressed
    End if
  11. be80be
    Aug 23, 2008
    4,792
    134
    morristown,tn
    Jon read the code I posted its saving the portb
    To a variable that you then test and reset in main it don't
    Get better then that
  12. JonSea
    Oct 1, 2012
    1,118
    90
    Seattle, WA
    Burt, just trying to make things clear for MrDEB. Sometimes he has trouble seeing the difference between what an example says and what he's doing.
  13. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    Thank you guys, Now it is more clear what I am trying to do.
    Burts code saves the button press variable then uses it in the main code body while Jons it appears to do basically the same thing?
    Didn't occur to me to use button.bits(x)=1
    Sounds easy enough. Will try both codes out but Jons looks easier to implement with a good explaniation of what is taking place.
  14. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    Well now it won't get out
    I changed as per suggestions but now it gets stuck. The LEDs stay on but appearently its not going into the approit routine. The greel led stays on.
    Kept getting conpile errors so I moved the sub portb interrupts.
    will investigsate futher but this is my progress = not much
    Code (text):
    'xxxxxxxxxxxxxxxxxxxx
    'interrupt
    'xxxxxxxxxxxxxxxxxxxxx
     RBIF = 0
          if portb.bits(6)=0 then led1 = 1
     endif
          if portb.bits(5)=0 then led2 = 1
     endif
          if portb.bits(4)=0 then led0 = 1
     endif
     EndIf
    End Interrupt
    Sub PORTB_Interrupts(Control As Boolean) // Small routine to enable/disable PORTB Interrupts.
     If Control = True Then
     RBIE = 1 //  interrupt enable bit
     Enable(PORTB_Change)
     Else
     RBIE = 0 //  port change interrupt enable bit
     Disable(PORTB_Change) //
     EndIf //
    End Sub
    Inline Sub Sleep()
     Asm
        Sleep
     End Asm
    End Sub
    'xxxxxxxxxxxxxxxxxxxxxxxxxxx
    //                          TURN DETECTION
    '   LEFT
     If led1 = 1  Then
        RBIF = 1
       // LED1 = 1  // GREEN       // NOTE I need to make ports LOW for transmission, HIGH for testing
        led2 = 0
        led0 = 0
        TX_pwr = 1               // turn on transmitter
        TX_Enable = 0            // enable encoder
             DelayMS(500)
        Toggle (LED1)
             DelayMS(500)
        LED1 = 0      // make sure its off
        TX_pwr = 0
        TX_Enable =1           // LOW for transmit
        rbie = 0
     End If
  15. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    I THINK I solved issue
    It seems to work except the low battery test. Needs work.
    Put the turn detections into subs. hopefully this is correct?
    Code (text):
    *  Name    : UNTITLED.BAS                                                   *
    *  Author  : [select VIEW...EDITOR OPTIONS]                                 *
    *  Notice  : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS]              *
    *          : All Rights Reserved                                            *
    *  Date    : 1/2/2013                                                       *
    *  Version : 1.0                                                            *
    *  Notes   :  this one works 1/10/2013                                                              *
    Device = 18F2420
    Clock = 8
    Config   LVP = OFF, mclre = off
    Include "InternalOscillator.bas"
    Include "utils.bas"
    Dim RBIF As INTCON.0  //port change interupt flag
    Dim RBIE As INTCON.3 //port change interupt enable
    Dim x As Byte
    Dim TX_Enable As PORTC.0
    Dim TX_pwr As PORTC.1
    Dim GD_bat As PORTC.2
    Dim led0 As PORTC.3 // blue
    Dim LED1 As PORTC.4  //green
    Dim led2 As PORTC.5  //red
    Dim s1 As PORTB.6
    Dim s2 As PORTB.5
    Dim s3 As PORTB.4
    Dim saveport As Byte
    //  TURN DETECTION SUB ROUTINES
    sub   RIGHT ()
        led2 = 1
        RBIF = 1
        led0 = 0
        LED1 = 0
       // led2 = 1    // RED
               DelayMS(500)      // just enough to see for testing
        Toggle (led2)
               DelayMS(500)
        led2 = 0     // make sure its off
        TX_pwr = 0
    end sub
    Sub  LEFT()
        LED1 = 1
        RBIF = 1
        led2 = 0
        led0 = 0
             DelayMS(500)
        Toggle (LED1)
             DelayMS(500)
        TX_pwr = 0
        RBIE = 0               // reset enable bit
     End Sub
    ' xxxxxxxxxxxxxxxxxxxxxxxxxx
    sub  BATTERY_TEST()
    ' BAD BATTERY
     If led0 = 1 And  PIR2.bits(2)=1 Then         // check hlvd flag
        TX_pwr = 1    //turn on transmitter
        led0 = 1     //blue led next to green BI color in final plan
             DelayMS(1000)
        Toggle(led0)
     End If
        PIR2.bits(2)=0
     ' GOOD BATTERY
     If led0 = 0 And PIR2.bits(2)=0 Then
           GD_bat = 1       // green led next to blue GD_bat = good battery
           DelayMS(1000)
           Toggle( GD_bat)
           DelayMS(1000)
           TX_pwr = 0                       //turn off transmitter
        EndIf
       // PIR2.bits(2)=0    // reset interrupt flag  DO I REALLY NEED TO RESET?
       // RBIF = 0      // Port change interrupt flag bit
    end sub
    'interrupt
     RBIF = 0
          If PORTB.bits(6)=0 Then LEFT()
     EndIf
          If PORTB.bits(5)=0 Then RIGHT()
     EndIf
          If PORTB.bits(4)=0 Then BATTERY_TEST()
     EndIf
     EndIf
    End Interrupt
     Else
     EndIf //
    End Sub
    Inline Sub Sleep()
     Asm
        Sleep
     End Asm
    End Sub
    //sssssssssssssssssssssssssssssssssssssssssss
    SetAllDigital
    Input(s1)
    Input(s2)
    Input(s3)
    Output(led0)
    Output(LED1)
    Output(led2)
    Output(TX_Enable)
    Output(TX_pwr)
    Output(GD_bat)
    HLVDCON = %00010111  // 3.12 volts
    PIR2.bits(2)=0       // clear HLVD flag
    PIE2.bits(2) = 1      //enable HLVD interrupt
    // Start Of Program...
    TRISB = %11110000 // Make PORTB7:4 all inputs
    TRISC = %00000000 // Make PORTC all outputs
    led0 = 0          // turn off all leds
    LED1 = 0
    led2 = 0
    TX_Enable = 1
    TX_pwr = 0
    GD_bat=0
    While True // Infinite loop
    PORTB_Interrupts(True) // Enable PORTB interrupts
        Sleep // Put the PIC to sleep and wait for a change
     // on PORTB 7:4
    Wend
  16. JonSea
    Oct 1, 2012
    1,118
    90
    Seattle, WA
    Sigh.
    1. Toggle to turn on an LED one time is STUPID as we have discussed.
    2. Exactly ONE command in the interrupt subroutine: WhatTheHellButtonWasPressed = PORTB. Parse it out in the main program loop.
    3. The HLVD routine is just hosed up. Read my code again and don't get creative.
    4. You ARE NOT using interrupts for the HLVD test...a button press activates the routine, so again, it should look just like what I posted....including setting and clearing register bits.
  17. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    Not using interrups for the HLVD?
    pressing the s3 button make a change on portb so is it not using the interrupt to WAKE?
    I will check if the pic is in SLEEP before pressing the s3. It appears to work? but maybe not??
    Will try and make some changes so only one command for the interrupt exit.
  18. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    This dosen't seem right?
    Code (text):
    RBIF = 0
    If s1=0 Then
    //LEFT()
    EndIf
    Unless all it is doing is reading the PortB contents?
    I see where I had the sub routes it has a possibility of getting lost.
  19. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    It appears the INTERRUPT is being used
    for all three button presses unless I am missing something?
    As for the HLVD it appears to work.
    I set the voltage in MPLAB higher than the trip point and the GREEN LED comes on(GD_bat) but if I lower the voltage below the trip point the blue led comes on (led0)
    I inserted LED routines within the interrupt and all the LEDs come on at appropriate times but it goes no further(runs the associated sub routine). I now know that that section of code is executing within the interrupt but want to figure out why it goes no further as it should. If I take out the LED routines all is well.
    Code (text):
     RBIF = 0
            If s1=0 Then
            led0 = 1       // TEST IF WORKING
      delayms(500)
            led0 = 0
          //LEFT()
     EndIf
          If s2=0 Then
      delayms(500)
      toggle(led0)
          //RIGHT()
     EndIf
          If s3=0 Then
          led1=1           // TEST IF WORKING
          delayms(500)
          led1 = 0
         // BATTERY_TEST()
     EndIf
     EndIf
    End Interrupt
  20. JonSea
    Oct 1, 2012
    1,118
    90
    Seattle, WA
    It's really spelled out in message #129.
    Before I contact my attorney to file a lawsuit against you for the blunt trauma to my head I have incurred because of you, let me try one last time.
    In the first block of code in message #129, replace
    PORTC = PORTB with
    Do NOT add anything else to the subroutine. NOTHING no matter how much you want to.
    The second block of code goes in the main program loop. Put the various actions in the appropriate places in the IF/THEN statements.
    You are not using HLVD to generate an interrupt. Use the code I originally posted to poll the HLVD register to determine status when the button is pressed which is what you claimed to want.
  21. MrDEB
    MrDEB Active Member
    Apr 16, 2007
    4,364
    22
    Will try your suggestions
    Confussed about the HLVD as it seems to work but will review and make suggested changes.
Share This Page
