    Dismiss Notice
how to tell if a capacitor is faulty?
Discussion in 'General Electronics Chat' started by confounded, Jun 3, 2009.
  1. confounded
    confounded New Member
    Feb 6, 2009
    204
    2
    london
    I suspect i have a faulty capacitor in my circuit.
    I connect the capacitors to my multimeter and i get the right capacitance.
    But I think one of them is shorting to ground.
    Am i right in thinking measuring capacitance does not prove a capacitor is ok?
    If so what other tests can i carry out to see if they are ok?
    I dont have a specific capacitor tester just a capacitance function on my multimeter.
  2. edeca
    edeca Active Member
    Apr 8, 2008
    589
    38
    England
  3. pcbheaven.com
    pcbheaven.com New Member
    May 11, 2009
    85
    1
    1. Measure with multimeter the capacitor in Ohm scale. The multimeter must shows at first small resistance and as time passes the resistance must increase.... This means the capacitor is still working.
    2. If electrolytic capacitor, charge it with 3 volts and put it across an LED. It should turn on for some fractions of secconds and then start fading out.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. confounded
    Feb 6, 2009
    204
    2
    london
    thanks for replying guys
    I've skimmed through those pages and i think i can use my multimeter set on resistance measure to see if the caps are shorted. :)
  6. edeca
    edeca Active Member
    Apr 8, 2008
    589
    38
    England
    Good job. Sorry for simply pasting links, but there are lots of good tutorials and repeating them here would be silly :)
  7. whiz115
    whiz115 Member
    Jan 29, 2007
    742
    2
    DotGR
    use an analog multimeter...
    a good capacitor should gradually show high enough resistance...
  8. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,623
    479
    L.A., USA Zulu -8
    If it's an electrolytic cap it may have excessive leakage at its operating voltage.
    Connect a multimeter set to measure current in series with the cap and connect to a DC power supply. Slowly increase the voltage to the rated cap voltage. After the cap is charged, the current should be no more than a few µA.
  9. stevez
    stevez Active Member
    Apr 3, 2003
    2,133
    9
    Rochester, NY
    I read some articles on reforming old capacitors and within those articles were tables of leakage current for various electrolytic capacitor values. You might use those tables with what crutschow has recommended as possibly go/no-go points.
    A relatively recent EE graduate took some large electrolytic capacitors that I had laying around and performed a number of tests on them. The professionals who helped him said the results were no surprise (all of the caps were 20+ yrs old) - the economy capacitors behaved as capacitors but at about 10% of their original value. What I don't know is if leakage current was predictably high or is totally unrelated to the degradation. You might have to measure both the value and the leakage among other parameters. Not sure if ESR is something that can change or degrade - or it just is what it is. I suppose it all depends on what is important to each application.
  10. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,319
    653
    Derbyshire, UK
    ONLINE
    ESR is the most important thing that changes, probably 95+% of all electrolytic failures are for high ESR. The vast majority of faults in modern electronics are high-ESR electrolytics - an ESR meter is of far more value for servicing than an LCR meter (but an LCR meter is still a nice toy :D ).
  11. Willbe
    Willbe New Member
    Aug 16, 2008
    1,236
    7
    MD
    Charge to 9v with a 9v batt. Discharge through a 1 megohm resistor. When the voltage reaches 37% of initial value, the time in seconds is the value in uF.
  12. stevez
    Apr 3, 2003
    2,133
    9
    Rochester, NY
    Nigel (or anyone who can answer) - may be a silly question but I'll ask anyway. As part of common failure modes for an electrolytic capacitor, would you expect to find a capacitor that shows a high ESR to also show an inappropriate value of capacitance or extraordinary leakage?
    Another way of saying it - can a capacitor retain it's capacitance yet have ESR go out of specification?
    I would think that all of those are related - but maybe they aren't.
  13. Nigel Goodwin
    Nov 17, 2003
    39,319
    653
    Derbyshire, UK
    ONLINE
    Yes it can, and most often does - although the capacitor is probably lower capacitance than it originally was, but still usually within tolerance. Leakage isn't likely to be a problem at all.
    The two ways to test are an ESR meter, circuit unpowered, or an oscilloscope, circuit powered.
    The Peak Electronics ESR meter I now use at work tests both ESR and capacitance, so it's doubly useful - and low cost as well.
    Peak Electronic Design Limited - Atlas ESR - Equivalent Series Resistance Meter and Capacitor Analyser - Model ESR60
  14. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    The reason ESR going up is bad is pretty easy to understand if you just think of every electrolytic capacitor in your circuit over time turning into a low pass filter.
  15. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
  16. Nigel Goodwin
    Nov 17, 2003
    39,319
    653
    Derbyshire, UK
    ONLINE
    I've got one of those as well, but it's not much use for servicing purposes, and really very few capacitors and resistors are unknown, but for inductors it's handy (not needed it yet though).
Share This Page
