    Dismiss Notice
How to shift message from left to right
Discussion in 'Microcontrollers' started by Parth86, Oct 18, 2017.
  1. Parth86
    Parth86 Member
    Dec 25, 2011
    538
    5
    Hi
    I am using 8051 MCU and keil software. How to shift message from left to right and then right to left in program
    Code (c):
    // Program for LCD Interfacing with 8051 Microcontroller
    #include<reg51.h>
    #define display_port P1                    //Data pins connected to port 2 on microcontroller
    sbit rs  =  P2^0;                                    //RS pin connected to pin 2 of port 3
    sbit rw  =  P2^1;                                   // RW pin connected to pin 3 of port 3
    sbit e  =  P2^2;                                    //E pin connected to pin 4 of port 3
    void msdelay(unsigned int time)  // Function for creating delay in milliseconds.
        unsigned   i,  j ;
        for(i = 0;  i <  time;   i++)
        for(j  =  0; j  <  1275;  j++);
    void lcd_cmd(unsigned char command)  //Function to send command instruction to LCD
        display_port  =  command;
        rs  =  0;
        rw  =  0;
        e  =  1;
        msdelay(1);
        e  =  0;
    void lcd_data(unsigned char disp_data)  //Function to send display data to LCD
        display_port  =  disp_data;
        rs  =  1;
        rw  =  0;
        e  =  1;
        msdelay(1);
        e  =  0;
     void lcd_init()                  //Function to prepare the LCD  and get it ready
        lcd_cmd(0x38);           // for using 2 lines and 5X7 matrix of LCD
        msdelay(10);
        lcd_cmd(0x0F);          // turn display ON, cursor blinking
        msdelay(10);
        lcd_cmd(0x01);         //clear screen
        msdelay(10);
        lcd_cmd(0x81);        // bring cursor to position 1 of line 1
        msdelay(10);
    void main()
          unsigned  char  a[15] = "ELECTRO-TECH";       //string of 14 characters with a null terminator.
          int  l = 0;
        lcd_init();
        while ( a[l]   !=  '\0')                                                   // searching the null terminator in the sentence
            lcd_data(a[l]);
            l++;
            msdelay(50);
  2. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,080
    326
    Brisbane Australia
    A quick guess to get you started.
    Code (text):
    void main()
        unsigned  char  a[16] = "ELECTRO-TECH    ";       //string of 14 characters with a null terminator.
        char i;
        lcd_init();
        while (1){
            char temp;
            //scroll in memory and display
            lcd_cmd(0x80);        //set to start of display
            temp=a[0];
            for(i=0;i<15;i++){
                a[i]=a[i+1];
                lcd_data(a[i]);
            //do final character
            a[15]=temp;
            lcd_data(temp);
            msdelay(50);
    • Like Like x 1
  3. Parth86
    Parth86 Member
    Dec 25, 2011
    538
    5
    Thanks for your quick response. Message shift character by character. I want to shift entire message
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Pommie
    Mar 18, 2005
    10,080
    326
    Brisbane Australia
    That's the only way it makes sense - it shifts 1 character every 50mS - the whole message every 0.8 seconds. To shift the whole message would leave it unchanged!
  6. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,827
    138
    morristown,tn
  7. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,245
    911
    Rochdale UK
    You need this function...
    Code (c):
    void Lcdprint(char* str)
       while(*str != 0)
          lcd_data(*str++);
    This will draw a line of text on the screen.. Then manipulate the string before the LCD write.
    Code (c):
    char lcd_buffer[17]  = {"Electro - tech  "};
    void rotateleft(void)
       char temp;
       temp = lcdbuffer[0];
       for( x = 1;x<16,x++)
          lcdbuffer[x] = lcdbuffer[x+1];
       lcdbuffer[16]=temp;
       lcdbuffer[17] = 0;
       Lcd_print(lcdbuffer);
    using a buffer should minimise flicker!! **THESE ROUTINES ARE UNTESTED**
  8. Pommie
    Mar 18, 2005
    10,080
    326
    Brisbane Australia
    I figured that shifting and then writing would not be necessary as the write to LCD is the slowest part, 1mS in this case.
  9. Ian Rogers
    Mar 28, 2011
    9,245
    911
    Rochdale UK
    No there seems to be a slower part!!!
  10. Pommie
    Mar 18, 2005
    10,080
    326
    Brisbane Australia
    The data write routines in the OP use a 1mS delay.
    Mike,
  11. Parth86
    Parth86 Member
    Dec 25, 2011
    538
    5
    You are making two separate routine rotateleft and rotateleft but I already have data routine lcd_data. if I replace my routine with your. I am getting error. What should be in main program ?
  12. Ian Rogers
    Mar 28, 2011
    9,245
    911
    Rochdale UK
    Code (c):
    char lcdbuffer[17]  = {"Electro - tech  "};
        unsigned   i,  j ;
        for(j  =  0; j  <  75;  j++);
        rs  =  0;
        rw  =  0;
        e  =  1;
        msdelay(1);
        e  =  0;
        rs  =  1;
        rw  =  0;
        e  =  1;
        msdelay(1);
        e  =  0;
    void Lcd_print(char* str)
       while(*str != 0)
          lcd_data(*str++);
         msdelay(20);
        msdelay(10);
        lcd_cmd(0x0C);          // turn display ON, cursor blinking
        msdelay(10);
        lcd_cmd(0x06);         //clear screen
        msdelay(10);
        lcd_cmd(0x1);        // bring cursor to position 1 of line 1
        msdelay(10);
    void rotateRight(void)
       char temp, x;
       temp = lcdbuffer[15];
       for( x = 15;x >0 ;x--)
          lcdbuffer[x] = lcdbuffer[x-1];
       lcdbuffer[0]=temp;
       lcdbuffer[16] = 0;
       lcd_cmd(0x80);
       msdelay(200);
       char temp,x;
       for( x = 0;x<15;x++)
       lcdbuffer[15]=temp;
       lcdbuffer[16] = 0;
       lcd_cmd(0x80);
       msdelay(200);
    void main()
       int  i ;
       lcd_init();
       while(1)
          msdelay(1000);
          i = 16;
          while(i--)
      rotateleft();                                           // searching the null terminator in the sentence
          msdelay(1000);
          i=16;
          while(i--)
      rotateRight();
    Had to mess up your delay function as mine runs at 12Mhz..
    Also I have left off the definitions as mine were different.
    • Like Like x 1
  13. be80be
    Aug 23, 2008
    4,827
    138
    morristown,tn
    Here the whole ball of wax from the iink I posted
    Code (text):
    #include<reg51.h>
    sbit rs=P3^5;   //Register select (RS)
    sbit en=P3^6;   //Enable (EN) pin
    sbit rw=P3^7;   //Read write (RW) pin
    char text[]={"microcntroler-project.com           "};
    void delay(unsigned int time)  //Time delay function
    unsigned int i,j;
    for(i=0;i<time;i++)
    for(j=0;j<5;j++);
                 //Function for sending values to the command register of LCD
    void lcdcmd(unsigned char value)
    P1=value;
    rs = 0;
        rw = 0;
        en = 1;
    delay(50);
    en=0;
    delay(50);
                 //Function for sending values to the data register of LCD
    void display(unsigned char value)
    P1=value;
    rs = 1;
    rw = 0;
    en = 1;
    delay(500);
    en=0;
    delay(50);
                 //function to initialize the registers and pins of LCD
                 //always use with every lcd of hitachi
    void lcdint(void)
    P1=0x00;    //Port 1 is used as output port
    P3=0x03;    //Port 3 higher bits from 2 to 7 are used as output and lower two bits are used to activate UART
         delay(15000);
         display(0x30);
         delay(4500);
         display(0x30);
         delay(300);
         display(0x30);
         delay(650);
    lcdcmd(0x38);
    delay(50);
    lcdcmd(0x0F);
    delay(50);
    lcdcmd(0x01);
    delay(50);
    lcdcmd(0x06);
    delay(50);
    lcdcmd(0x8F);
    delay(50);
    void main()
    unsigned int i;
    lcdint();
     i=0;
    while(text[i]!='\0'){
     display(text[i]);
     delay(200);
     lcdcmd(0x18);
     delay(600);
     i++;
Share This Page
