    Dismiss Notice
How to rwgulate the white "noise"
Discussion in 'Repairing Electronics' started by Kryten, Dec 8, 2008.
  1. Kryten
    Kryten New Member
    Oct 29, 2007
    376
    1
    Stavern, Norway
    Hi Not sure this is in the correct category but anyways...
    i got a 37' LCD from LG. My problem is that when i look at TV i gett nois when the screen is withe. Im using a scart from my satelite decoder, is there any way to regulate the withe level?
    The noise only occurse when im using my sat decoder NOT when i look at DVD (also via scart).
    The nois is a sound that (i would think ) is about 100 - 500 Hz and it dosen't matter if i mute the TV or not its always there (when all white or brigth colors)
    can anyone advice me on what to do?
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    Presumably it's mechanical noise from the inverter or PSU - as it's at a low frequency it may be the PSU is 'hunting' and putting ripple on the output.
    Unless it's particularly loud, it may be 'normal' and within design limits.
  3. Kryten
    Kryten New Member
    Oct 29, 2007
    376
    1
    Stavern, Norway
    Well Nigel its quite loud. enough too "shout" over TV audio when i look at the TV and have a low volume on. And since its only when i use my Sat decoder i was thinking it might bee that the decoder puts out a withe signal thats too high.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Nigel Goodwin
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    Common problems are capacitors going high ESR, you may have some that have done just that - worth looking inside see if you can see any with bulging tops.
  6. Kryten
    Kryten New Member
    Oct 29, 2007
    376
    1
    Stavern, Norway
    Ok but is it the TV or is it the decoder? got any good guess?
  7. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    If your DVD is fine then it's probably the decoder.
  8. Kryten
    Kryten New Member
    Oct 29, 2007
    376
    1
    Stavern, Norway
    Hmm must chekc to see if i cant tune it in to correct signal levels
Share This Page
