    Dismiss Notice
How to programm PIC with Genius 540 programmer
Discussion in '8051/8951' started by Qaisar Azeemi, Jul 26, 2012.
  1. Qaisar Azeemi
    Qaisar Azeemi Member
    Oct 24, 2011
    157
    1
    South of Asia
    HI all!
    i am sorry again if it is wrong place for this post..... i request administrator of the forum to make separate place for PIC microcontrollers. Thank you.
    i am new to PIC micro controllers and using pic16f877a to learn using pic controllers. i have burnt the Hex file in my pic16f877a using Genius 540 Universal programmer. when i try to load my hex file it ask me the information about my file; that; is it hex (motorola), hex (intel), bin.... etc.
    i tried to burn using all the info turn by turn but it failed.... kindly Guid me how to program using Genius540 universal programmer. i am using MPLAB IDE V8.83.
    Thanking u in anticipation.
  2. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
  3. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    thank you, i have posted the same post there.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
    Check if your programmer is supported by MP Lab, because it supports only some programmers not all of them, if not, try to get your programmer own software and use it to download your Hex file.
  6. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    Genius G540 Suppports all Microchip controllers.
  7. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    Genius programmer gives me this error while loading Hex file "Non configuration worde in hex file. please set it after loading".
  8. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
    in this case you need to post your code to check whats wrong with it, because it is clearly talking about configuration word which essential part of the program.
  9. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    here is my test code. simply blink the leds connected to Port C.
    #include<Pic16F877A.h>
    //#include <htc.h>
    void DELAY_ms(int);
    void main()
    unsigned char j=1;
    TRISC=0;
    for( ; ; )
    PORTC=j;
    DELAY_ms(1000);
    j=j<<1;
    if (j==0)
    j=1;
    void DELAY_ms(int x)
    int i,j;
    for(i=0; i<x; i++)
    for(j=0; j<500; j++);
    code is successfully compiled by compiler. but when i try to load the hex file via genius programmer it just get the fist line of hex file and ignore the others.
    the hex file of the above code is:
    :060000000A128A11972F7D
    :100F2E0083010A128A119B2FF9010314F90D8316FE
    :100F3E0003138701A22F7908831203138700E83069
    :100F4E00F0000330F1000A128A11C2270A128A1128
    :100F5E007908F7007707F8007808F900F908031DFB
    :100F6E00B92FBA2FA22FF9010314F90DA22FA22F18
    :100F7E000A128A110028F301F401F02FF501F6018F
    :100F8E007608803AFF0081307F02031DD02FF430A7
    :100F9E007502031CD32FD42FD62FEA2FEA2F013040
    :100FAE00F5070318F60A0030F6077608803AFF00B8
    :100FBE0081307F02031DE52FF4307502031CE82FEC
    :100FCE00E92FD62FEA2F0130F3070318F40A003069
    :100FDE00F4077408803AF2007108803A7202031D19
    :100FEE00FA2F70087302031CFD2FFE2FC52FFF2F43
    :020FFE000800E9
    :00000001FF
    but compiler just load the first line of the file....
    0A128A11972F
    and ignore the other bytes..... i cant understand y??? :-(
  10. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
  11. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
    I did most of my work in assembly, in that you have to add a Cofig word that will set your fuses, such as :
    Program Code Protection (prevents readback of program code via programming hardware)
    Data Code Protection (prevents readback of data EEPROM via programming hardware)
    Low Voltage Programming
    Brown Out Reset
    Sets MCLR as either External Master Clear or digital input
    Power Up Timer
    Watchdog Timer
    Sets the oscillator type (be it internal, external RC or external crystal)
    it can be written in letters, or it may combined in a Hexadecimal number started with 0x####.
    below is one of Nigle Goodwin tutorial, where translated in this forum into C, you can see __CONFIG word in the third line.
    Code (text):
    #include <pic.h>            // pic specific identifiers
    # define _XTAL_FREQ 4000000
    __CONFIG(0x3D18);                   // Config bits
    void main(void)             // program entry
        CMCON = 0x7;            // Comparitors off
        TRISA = 0x0;            // Both ports
        TRISB = 0x0;            // as outputs
        while(1)                // Loop forever
            PORTB = 0xff;       // All on!!
            PORTA = 0xff;
            __delay_ms(180);    // Wait a while
            PORTB = 0x0;        // All off!!
            PORTA = 0x0;
        }               // End!!
    • Like Like x 1
  12. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    my problem is solved. i am using mikroC now. its easier than MPLAB IDE. i am now fall into another interesting problem:
    here is my circuit diagram. simulating well in Proteus.
    Problem: when i remove the 0.1uf capacitor from the power line to the microcontroller the circuit start working but still it needs to touch the oscillator once. if i don't touch the oscillator it will not work and remains idle. so the crystal needs a jerk of induced voltages to start through my finger.
    i am using vero-board. value of capacitor is 22pf and i think i've set the configuration word to XT for 4MHz crystal.
    about high frequency crystals is that I've used 12MHz crystals with 8051 family controllers thousand of times; and it didn't create any problem. why high frequency crystal is an issue in PICs?
    my coading is below:
    and here is the configuration bit setting in Genius programmer;
  13. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,151
    907
    Rochdale UK
    ONLINE
    I think that 30k for a reset cap is too high, especially if you have a 10uf cap there.... It'll take a week to startup..
    I use a 10k and use the internal cap...
    Secondly... The 4Mhz Xtal uses a mode called XT... Which you have indeed selected.... The correct setting is HS.... FOSC0 = 0 FOSC1 = 1
    HS is for xtals 8Mhz and above...
  14. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
    Two suggestion:
    1- I'm using MikroC, but found it is limited with its ready made modules.
    2- To start with PIC, you can use the once that has internal oscillator to avoid one cause of uncertainty.
  15. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    Oh sorry i acctually connectd 4.7k ohm resistor in my hardware, i mistakenly didn't change the value of minresis 30k to 4.7k in the proteus. yes i have selected XT oscillator in the Genius programmer setting but even if i select HS; it runs the program in my hardware..... but still with the same problem that crystal starts its "Tick Tick" when i touch its one leg at pin 13. i can't understand the reason and don't know where i am going wrong.
    kindly elaborate a bit more... you mean to say that mickro-c is not a good compiler and can't be used for large programs because of limitations???
    and what is internal oscillator?
  16. Qaisar Azeemi
    Oct 24, 2011
    157
    1
    South of Asia
    oh yap i did it.......... :)
    just only tick
    fosc1
    wdt0
    wdt1
    debug
    and untick all others in Genius programmer. and i solved the problem/issue. :)
  17. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
    MikroC ready-made modules makes your life easy, but limited to them, you can't do any amendment for there parts, I've faced this when used LCD module and wanted to show my own character.
    PICs with Internal oscillator such as 16F628 and 12F629 are having internal oscillator where you can use and forget about Xtal connection in case your circuit is not functioning properly . Although it is not as accurate as the Xtals, but it is good especially where time is not of great important.
  18. aljamri
    aljamri Member
    Jun 12, 2006
    694
    6
    These are the fuses, which if all combined, in PIC term called Configuration Word . This is the error "Non configuration worde in hex file. please set it after loading" you are talking about in post #6.
  19. ileperuma
    ileperuma New Member
    Apr 30, 2012
    1
    0
    "Genius programmer gives me this error while loading Hex file "Non configuration worde in hex file. please set it after loading".
    i am also same problem .and using genius g540 programmer please advice me how setting the configuration bit in Genius programmer;
    thanks all of you
Share This Page
