    Dismiss Notice
How to get it in??
Discussion in 'Microcontrollers' started by yamaraj, Jun 30, 2003.
  1. yamaraj
    yamaraj New Member
    Feb 19, 2003
    15
    0
    Hi i'm making an ultrasonic range meter. http://www.interq.or.jp/japan/se-inoue/e_pic6_6.htm
    ad i am using mplab to make the asm into a hex file. I'm fine upto there.But now how do i get that hex into the chip.
    the pic being used is PIC16F873 so any emulators in particular??
    thnx for the help :D
  2. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    Ok, so you got your asm file converted into hex, what you need now is a programmer to "blow" the hex into the pic........
    look here:
    http://www.lancos.com/prog.html
    for a suitable programmer, you can either buy/build it.......email him he's quite helpful.
    the programmer runs from the serial port, you can download the software for it too or else use ic-prog, which is what I use..
    HTH Chip
  3. yamaraj
    yamaraj New Member
    Feb 19, 2003
    15
    0
    thnx for the reply.i had a look and well did get quite alot.Can i use any programmer or does it have to be specific
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    there are basically 2 types of programmer.....Serial based and parallel based.......this refers to the port connection on your pc.
    The Pony Prog device uses the serial port........and his software.
    Icprog is suitable for both serial and parallel programmers but care is needed to ensure compatability........
    There is other software available as hardware too......depends what you want and what you want to do with it...........personally I have several programmers, some commercially produced and others I've built myself.......
    Happy hunting 8)
  6. TheAnimus
    TheAnimus New Member
    Jun 22, 2003
    116
    1
    England
    The type of the programmer also somtimes refers to how the PIC is programmed, some PICs can be programmed in a Parallel fasion, while most are programmed in a serial manner, its best that you check the datasheet of the PIC you wish to use. From memory i think the 873 is programmed in a seriel manner.
Share This Page
