    Dismiss Notice
how print pointer to a string on LCD
Discussion in 'AVR' started by Azadfalah, Apr 10, 2017.
  1. Azadfalah
    Azadfalah New Member
    Feb 12, 2017
    2
    0
    Hello friends
    how can in print pointer to a string on LCD
    char a[] = "Hello world";
    char *ptr2 = a; // Points to the 'H' of "Hello world"
    how can print *ptr2
    codevisionAVR Atmega64 , alcd.h
  2. Daniel Wood
    Daniel Wood Member
    Jun 15, 2012
    69
    9
    Derby
    ONLINE
    Strings are generally null terminated.
    Stick it in a while loop with the expression: while(*ptr2 != 0)
    print out each character at a time and then increment the pointer, inside the loop. A bit like:
    printf("%c", *ptr2++);
    • Like Like x 1
  3. Daniel Wood
    Daniel Wood Member
    Jun 15, 2012
    69
    9
    Derby
    ONLINE
    Might I add, your string must end with a null character (0 in decimal) with the above technique, otherwise you will end up printing data from other areas of memory.
    Another (likely safer) way is to have an integer variable called a_length, with the number of characters specified explicitly.
    Then you print and increment the pointer inside a "for" loop until all the characters have been iterated.
    • Like Like x 1
Share This Page
