Hot air rework, blisters on PCB?
I'm trying to repair a PCB and I've been a bit too aggressive using my hot air rework station. The PCB has formed "blisters" that crack and seep out black fluid (which I have no idea what is).
Did I destroy the PCB, or are the traces inside probably still intact? I don't know how many layers the PCB has.
Its the resin in the FRC board.. I sometimes get a bit of melted resin when I resolder... A little is kinda normal.
Not necessarily! You will need to run continuity tests... You can always run external wire to bridge any broken tracks..
