High power low frequency RF Amplifiers
naumank
Hi all
I am searching some commercially available industrial grade power amplifiers:
1.In the frequency range of 80 KHz to 140 KHz with output power of 2 KW to 50 ohm load in pulsed mode (<10% Duty Cycle
2.In the frequency range of 400 KHz to 450 KHz with output power of 5 KW to 25 ohm load in pulsed mode (<5% Duty Cycle
Kindly help me in suitable selection.
Thanks & Regards
I do not know of anything but I am thinking.
What are you amplifying? Sign wave, pulse, square wave?
1) 300V pk into 50 ohms. (600V p-p) I have used AM broadcast transmitters that can do that. (sign wave only) 100%.
When you say 5% and 10%; Is the output a pulse that is off 90% and on 10% or will the amplifier be used for 1 second and off f10 seconds?
Thanks for reply. I am amplifying sine wave. 5% or 10% means that pulse will be on for 5/10 % and will be off for 90/95% time.
Got that, but how long does the pulse last (duration)?
Hi all
Thanks & Regards
While lightly off-topic, I couldn't help but notice that your proposed frequency ranges fall into **broken link removed** (pages 2-5).
Where are you located? Are your load(s) dummies or antennae?
If using antennae, pumping out a few kilowatts (even if only a few milliseconds,) can attract a lot of unwanted attention (since it's illegal to do so without a license).
I googled, "2kW 140 kHz marine chirp amplifiers" and this popped up.
This Garmin chirp amp doesn't meet your exact needs, but should give you an idea of search terms and a price range.
