Hi-Tech C Compiler: What am I doing wrong?
micro571
I am trying to program a PIC16F877A. I know my hardware is good because I can load on the LED blink program from here: blink a LED and it works.
I am trying to do an led blink program using the Hi-Tech C Compiler. I have it specified as the tool chain in MPLab.
Here is my code:
#include <pic.h>
#include <conio.h>
#include <stdlib.h>
#include <stdio.h>
#include <ctype.h>
#include "delay.h"
//#include "delay.c"
//void delay(void);
//#define _16F877
// __CONFIG(UNPROTECT|BODEN|FOSC1|BKBUG|WRT);
//__CONFIG( XT & WDTDIS & PWRTDIS & BORDIS & LVPDIS & WRTEN & DEBUGDIS & UNPROTECT );
void main (){
ADCON1 =0x06 ; // Changes PORTA to digital
CMCON = 0x07 ; // Disable analog comparators
PORTA = 0x00 ;
PORTB = 0X00 ;
PORTC = 0X00 ;
PORTD = 0X00 ;
PORTE = 0X00 ;
TRISA = 0x00 ; // Configure PORTA as output
TRISB = 0X00 ;
TRISC = 0X00 ;
TRISD = 0X00 ;
TRISE = 0X00 ;
while(1){
PORTA = 0XFF ;
PORTB = 0XFF ;
PORTC = 0XFF ;
PORTD = 0XFF ;
PORTE = 0Xff ;
DelayMs(500);
PORTA = 0X00 ;
PORTB = 0X00 ;
PORTC = 0X00 ;
PORTD = 0X00 ;
PORTE = 0X00 ;
DelayMs(500);
The code compiles, but nothing happens when I load the hex file.
It's a simple program. I must be missing something small. Any suggestions?
just a thought how many leds do you have hooked to that chip it cant lite 33 all at one time
try this and see if it works change the xtal setting to match yours
#include <htc.h>	// Required to interface with delay routines
#ifndef _XTAL_FREQ
 // Unless already defined assume 4MHz system frequency
 // This definition is required to calibrate __delay_us() and __delay_ms()
 #define _XTAL_FREQ 4000000
#endif
void main(void){
PORTA = 0x00 ;
PORTB = 0X00 ;
PORTC = 0X00 ;
PORTD = 0X00 ;
PORTE = 0X00 ;
TRISB = 0X00 ;
TRISC = 0X00 ;
TRISD = 0X00 ;
TRISE = 0X00 ;
while(1){
PORTA = 0XFF ;
PORTB = 0XFF ;
PORTC = 0XFF ;
PORTD = 0XFF ;
PORTE = 0Xff ;
__delay_ms(100);
PORTA = 0X00 ;
PORTB = 0X00 ;
PORTC = 0X00 ;
PORTD = 0X00 ;
PORTE = 0X00 ;
__delay_ms(100);
I changed your reference code value from 4MHz to 20MHz and compiled.
As is, the new code produces an error:
Error [499] ; . undefined symbol:
___delay_ms (877.obj)
I'm using the Hi-Tech C compiler, v9.60.
At the top of the delay.h file I was referencing in my code, I had defined:
#define PIC_CLK 20000000
Can you try this,
#include <pic.h>
#include <conio.h>
#include <stdlib.h>
#include <stdio.h>
#include <ctype.h>
#define _16F877
__CONFIG( HS & WDTDIS & PWRTDIS & BORDIS & LVPDIS & WRTEN & DEBUGDIS & UNPROTECT );
#define	XTAL_FREQ	20MHZ
#include "delay.c"
void main (){
    PORTA = 0x00 ;
    PORTB = 0X00 ;
    PORTC = 0X00 ;
    PORTD = 0X00 ;
    PORTE = 0X00 ;
    TRISB = 0X00 ;
    TRISC = 0X00 ;
    TRISD = 0X00 ;
    TRISE = 0X00 ;
    while(1){
        PORTA = 0XFF ;
        PORTB = 0XFF ;
        PORTC = 0XFF ;
        PORTD = 0XFF ;
        PORTE = 0Xff ;
        DelayMs(500);
        PORTA = 0X00 ;
        PORTB = 0X00 ;
        PORTC = 0X00 ;
        PORTD = 0X00 ;
        PORTE = 0X00 ;
        DelayMs(500);
I have v9.65 and it wouldn't build your code
I tried the code as-is and got a bunch of errors:
Error [482] ; . symbol "_DelayMs_interrupt" is defined more than once in "877.obj"
Error [482] ; . symbol "_DelayS" is defined more than once in "877.obj"
Error [482] ; . symbol "_DelayMs" is defined more than once in "877.obj"
Error [482] ; . symbol "_DelayBigMs" is defined more than once in "877.obj"
Error [482] ; . symbol "_DelayBigUs" is defined more than once in "877.obj"
Error [482] ; . symbol "_delayus_variable" is defined more than once in "877.obj"
I changed "delay.c" to "delay.h" and compiled...
It worked! I've got a blinking led now.
Thanks for your help. I'm guessing it's the config parameter that did it.
I had tried it with this config earlier:
but that didn't work.
Thanks again for your speedy responses!
Now it's time to upgrade blinky led program to something more useful. :)
Doing a bit of trial and error with the config line; I needed to specify HS (presumably high-speed) instead of XT (external??) for the oscillator selection bits.
HS and XT are both external here data sheet has about it
14.2.1 OSCILLATOR TYPES
The PIC16F87XA can be operated in four different
oscillator modes. The user can program two configuration
bits (FOSC1 and FOSC0) to select one of these four
modes:
• LP Low-Power Crystal
• XT Crystal/Resonator
• HS High-Speed Crystal/Resonator
• RC Resistor/Capacitor
a few things:
1) you will need to make sure that the fuses are set in a way consistent with your circuit. do you use the internal rc oscillator? for example.
2) I am assuming that the port settings are right. but you typically set TRISA/B... registers before you set the ports.
3) the errors with regarding to delay() is due to the header files.
how about this one?
#include	<pic.h>
#include	<conio.h>
#include	<stdlib.h>
#include <stdio.h>
#include	<ctype.h>
#include "delay.h"
//#include "delay.c"  // you may or may not be able to comment out this. depending on what's in delay.h and delay.c
//void delay(void);   // it is always a good idea to declare functions explicitly
//#define _16F877
void main (){
TRISB = 0X00 ;
TRISC = 0X00 ;
TRISD = 0X00 ;
TRISE = 0X00 ;
PORTA = 0x00 ;
PORTB = 0X00 ;
PORTC = 0X00 ;
PORTD = 0X00 ;
PORTE = 0X00 ;
while(1){
  DelayMs(500);
  PORTA = ~PORTA ;
  PORTB = ~PORTB ;
  PORTC = ~PORTC ;
  PORTD = ~PORTD ;
  PORTE = ~PORTE ;
You no I've tried toggle like that and it doesn't blink the led
while(1){
  DelayMs(500);
  PORTA = ~PORTA ;
  PORTB = ~PORTB ;
  PORTC = ~PORTC ;
  PORTD = ~PORTD ;
  PORTE = ~PORTE ;
Where that on a 16f877a not a 18fchip
That's what I get for only reading one post down, but it illustrates the point, and a good reason to use an 18F.
On the 16F you need to toggle a variable and write it to the port
char toggleMe;
toggleMe = 0x00;
while(1)
  toggleMe = ~toggleMe;
  PORTA = toggleMe;
I found why the chip I was using has adc on portC so I needed this
void main (){
ANSEL = 0;                  // makes PORTC digital
PORTC = 0;                 // Initialize PORTC
TRISC = 0;                 // Configure PORTC as output
while(1){
  Delay_Ms(100);
  PORTC = ~PORTC;
works find like this LOL
If PORTC=~PORTC doesn't work then some possible reasons are,
1. You have the pins still set to analogue as pointed out by Burt.
2. You have overloaded the pins and this is forcing them high/low. Normally by connecting LEDs without series resistors.
3. You forgot to switch the pins to output.
4. The pins are configured for some other peripheral.
5. One of the other reasons for pics not working - not programmed, no oscillator, no power etc.
the fact using an intermediate variable can toggle a port suggests that the port itself is in the right mode.
I am curious about this as well. I have never encountered an example where PORTA=~PORTA; does not work.
3v0, do you have an actual code where this is known to not work?
Nope.
I was thinking about the Read-Modify-Write problem on the 16F's.
Burt said PORT=~PORT did not work. According to his post it did not work on any of the ports. I did not suspect he had not configured the port correctly.
Try it on any pic chip with analogue pins. Any pins that are analogue work well as digital outputs but when you read them they always return zero. Hence why a copy will work.
