Help with ultrasonic sensors!
ro5man
Hey all,
First of all,I a total noob with sensors so I need a little help.
I need help with my ultrasonic receiver circuit,I got the transmitter circuit working (40kHz etc).I want the output to be based on the intensity of the received signal so that I can measure the voltage but I keep getting an output based on the frequency of the received signal.What kind of circuit can you guys recommend me so that I get a voltage output rather than a frequency output?
Many thanks to those who reply!
Hey all,
hi,:)
Can you post your receiver circuit.?
For a voltage output relating to the intensity received, try connecting the receiver to an amplifier (must be capable of passing the 40kHz) followed by a peak-detector.
Hi there, I am also building a transmitting circuit. Would it be possible for u to post a circuit diagram? Thanks
As dougy said, create a non inverting amplifier with an OP-AMP (you may need 2 stages with something like a TL082 due to the gain bandwidth product), make sure you have an offset null on the input as well.
I would not even consider something like a 741, the GBP and slew rate make it horrible for 40 kHz amplification - in fact with enough gain you will end up with triangular waveforms...
Then just have a peak detector on the output (diode, cap and parallel resistor if the load is not sufficient to discharge rapidly enough).
(The only place I think a 741s should reside is in history books and teaching students the basics of op amps, I would never consider using one...).
