The following code was compiled in CCS and counts from 0-9 w/ output to the following LCD (Common Cathode)
https://www.electro-tech-online.com/custompdfs/2013/04/LCD-S2X1C50TR.pdf
This code works but I'm trying to make two modifications:
1) Add a second digit without multiplexing
2) Substitute a 2 or 3 digit variable instead of the counter
The PIC has a built in LCD controller (16F914)
Any help in terms of how this might be coded would be greatly appreciated.
Thanks!
Thanks!
/* Connections
Seg Port
A1 – RC1
B1 – RC2
C1 – RC4
D1 – RC3
E1 – RB4
F1 – RB1
G1 – RB0
A2 – RD1
B2 – RD7
C2 – RD4
D2 – RD3
E2 – RD5
F2 – RD6
G2 – RD0
1BC – RD6
Com/Cath - Gnd
#include <16F914.h>
#use delay (clock=4000000) // oscillator frequency for delay_ms()
/***** CONFIGURATION *****/
// ext reset, no code protect, no watchdog, 4 MHz int clock
#fuses MCLR,NOPROTECT,NOWDT,INTRC_IO
/***** LOOKUP TABLES *****/
// pattern table for 7 segment display on ports B and C
const int8 pat7seg[10] = {
// RC4:1,RB4,RB1:0 = CDBAEFG
0b1111110, // 0
0b1010000, // 1
0b0111101, // 2
0b1111001, // 3
0b1010011, // 4
0b1101011, // 5
0b1101111, // 6
0b1011000, // 7
0b1111111, // 8
0b1111011 // 9
/***** MAIN PROGRAM *****/
void main()
unsigned int8 digit; // digit to be displayed
//*** Initialization
// configure ports
setup_adc_ports(NO_ANALOGS); // disable all analog and comparator inputs
setup_comparator(NC_NC_NC_NC); // -> RB0, RB1, RC0, RC1 digital
//*** Main loop
while (TRUE)
// display each digit from 0 to 9 for 1 sec
for (digit = 0; digit < 20; digit++)
// display digit by extracting pattern bits for all pins
output_b((pat7seg[digit] & 1<<2) << 2 | // RB4
(pat7seg[digit] & 0b00000011)); // RB0-1
output_c((pat7seg[digit] >> 2) & 0b011110); // RC1-4
// delay 1 sec
delay_ms(1000);
