    Dismiss Notice
Help required to program a PIC
Discussion in 'Microcontrollers' started by ERGOYE, Aug 31, 2017.
  1. ERGOYE
    ERGOYE New Member
    Aug 29, 2017
    11
    0
    Hi guys good morning, i am new for this forum, I need your help on programming PIC16F84 M.C. i have no idea to program it. I was trying to build one of EPEmag project which is called "MOODPICKER" there in the project i found this pre-programmed microcontroller ....i search for source code in the EPE website i found one file but i am not sure wether it is the right thing or not to program the PIC.....please can you help me...to program it? I can send you all the information what you need. Thank you for your time and patience
  2. Jon Wilder
    Jon Wilder Active Member
    Oct 22, 2010
    865
    82
    Fresno, CA
  3. ERGOYE
    ERGOYE New Member
    Aug 29, 2017
    11
    0
    ftp://ftp.epemag.wimborne.co.uk/pub/PICS/moodPICker/mindpic.asm
    This is additional information for who would like to reply to me.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ERGOYE
    ERGOYE New Member
    Aug 29, 2017
    11
    0
    I bought already
  6. ERGOYE
    ERGOYE New Member
    Aug 29, 2017
    11
    0
    ftp://ftp.epemag.wimborne.co.uk/pub/PICS/moodPICker/moodpicker.txt
  7. ERGOYE
    ERGOYE New Member
    Aug 29, 2017
    11
    0
    ftp://ftp.epemag.wimborne.co.uk/pub/PICS/moodPICker/mindpic.obj
  8. Jon Wilder
    Oct 22, 2010
    865
    82
    Fresno, CA
    Oh you meant you need someone to assist you in how to write code for one?
  9. Les Jones
    Les Jones Well-Known Member
    May 15, 2015
    1,474
    191
    Lancashire UK
    Your link in post #3 is the source code. (The .asm file is a source code file.) If you do a search for "EPE TK3 programmer " or "EPE PK3 programmer" I think you will find a link to an assembler that will assemble the source file from post #3. It is not to difficult to modify the .asm file so that it can be assembled with MPASM (Microchip assembler)
    Les.
    • Agree Agree x 2
    • Thanks Thanks x 1
  10. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    Since the code is in Assembly and you are apparently new at this, I suggest going going here and downloading MPLab IDE 8.92 that is appropriate for your PC: http://www.microchip.com/development-tools/downloads-archive
    You will also need a 32.768 kHz crystal for that chip. If you can change to the almost identical 16F628A chip, it has internal oscillators. But you will need to change the code slightly to use them. We can help you do that.
    John
    • Informative Informative x 1
    • Thanks Thanks x 1
  11. Jon Wilder
    Oct 22, 2010
    865
    82
    Fresno, CA
    MPLAB X has gotten substantially better. I boycotted it too in favor of MPLAB 8 because X was just not usable for me the first couple of years. But I highly recommend the latest version of MPLAB X instead.
    http://www.microchip.com/mplab/mplab-x-ide
  12. jpanhalt
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    When our fearless leader (Ian Rogers) switches, so will I.;)
    More seriously, I have considered trying MPLAB X a few times recently, if only for the newer chips and fewer hangups. The thinking behind my comment was that for someone quite new, 8.92 is pretty darn intuitive. Albeit, that opinion is based only on my experience with X shortly after it came out.
    • Like Like x 1
    • Thanks Thanks x 1
  13. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,305
    914
    Rochdale UK
    ONLINE
    I am reviewing MPLBX 4 as we speak.... BUT!! It's the multi project thing that still gives a headache... When two + projects are open the interface still confuses the linker where relevant files are.... If used with one project at a time, then it's quite stable. But! I have a bit more testing to do...
    Fearless leader!!! LOL Miles off the mark...
    • Agree Agree x 1
  14. nigel wright
    nigel wright New Member
    Sep 1, 2017
    21
    1
    You can pick up cheap Chinese PICKIT3 clones on ebay.
    I paid £20 for one with a ZIF multiple socket interface.
  15. Colin
    Colin Member
    Sep 25, 2003
    418
    23
    Australia
    They are as low as $12.00 USD post free but no socket to "burn" the chip.
  16. nigel wright
    Sep 1, 2017
    21
    1
  17. jpanhalt
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    Apparently, TS already has a PK3 (or clone), see post #4.
    • Thanks Thanks x 1
  18. Colin
    Colin Member
    Sep 25, 2003
    418
    23
    Australia
    You need this
  19. BobW
    BobW Active Member
    Apr 28, 2010
    521
    54
    Canada
    I'd double check the connections to that burner board before programming a PIC with it. There are at least two different common pin arrangements for power supply, clock, and data lines.
  20. nigel wright
    Sep 1, 2017
    21
    1
    I always add a 6 way molex connector on my pcb for programming the PIC.
    Saves removing and inserting the PCI each time.
  21. jpanhalt
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    Re: Burner boards
    1) Only a 5-pin connector is needed for ICSP; although, the Microchip factory connector is 6 pin. I blank off the socket and use a 6-pin header. The helps ensure proper orientation when the room or my eyes are dim. As time progresses, that connector is getting disproportionately large compared to everything else on the board.
    2) Microchip recommends against any passive devices in the bidirectional clock or data lines to the programmer. It typically recommends resistors for isolation from the rest of the circuit when those pins are used for other things. See: http://microchipdeveloper.com/dtda:icsp-considerations. Colin's adapter has LED's labeled clock and data. How are they connected?
    3) I prefer a ZIF socket on my "burner boards" when I am not doing ICSP. As BobW points out, there are several different configurations needed. The particular boards I use allow changes to the configuration by jumpers (www.j1sys.com).
    John
Share This Page
