Help in EZ dowload for 8051 !
abc123456
Who can tell me , What 's 2150 , 1150 and 250 in circuit EZ dowload for 8051 ?
it's here **broken link removed**
thank you very much [/url]
I'll hazard a guess and say they are precision resistors to give the required output voltage.(in ohms)
I agree!, they are the resistor values in ohms - as is obvious if you compare the labeling in the rest of the circuit. Presumably you would have to make them using parallel resistors, or presets.
StupidDum said:
2150, 1150...
these resistor values are strange...
Presumably they are to give accurate voltages for the programmer, switching between two different values - which is why I suggested parallel resistors or presets - personally I'd probably use presets with series resistors, something like 470 ohm presets with either 1800 or 1K in series.
