    Dismiss Notice
Function Generators with High Output Voltage
Discussion in 'High Voltage' started by lusebass, Nov 1, 2017.
  1. lusebass
    lusebass New Member
    Nov 1, 2017
    3
    0
    Hi there! I'm looking for some function generators which supply high output voltage (kV if possible). This is for a research so I only need 3 different brands. Of course they cannot be obsolote. They would be used for testing breakdown voltage and faults on components and electronic equipment.
    Common signal generator's output voltage is 20 Vpp. Some supply a little more (30 Vpp for example but this voltage is not useful for what I need to do).
    I only could find this one (on this forum):
    http://trekinc.com/products/615A1.asp
    Another option could be using a high output voltage amplifier for each function generator. Hope you can help me. I'll keep on searching anyway. Thanks!
  2. JimB
    JimB Super Moderator Most Helpful Member
    Sep 11, 2004
    6,353
    586
    Peterhead, Scotland
    ONLINE
    Why do you need three different types of generator?
  3. lusebass
    lusebass New Member
    Nov 1, 2017
    3
    0
    Because I have to make a comparison and choose the one which is best.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,304
    969
    Loveland, CO USA
    There are "0" brands!
    You can get a amplifier that goes on the output of a generator.
    What frequency?
    Sign wave? Square?
    What voltage 1kv?
    The last person to ask this question here wanted many kV and mhz and many amps. Maybe you can get Kv OR mhz OR amps but not at the same time.
  6. lusebass
    lusebass New Member
    Nov 1, 2017
    3
    0
    What frequency? I'm not looking for an specific frequency range. If it's a wide range, better.
    Sign wave? Square? Sign wave, square, triangle, sawtooth and that's enough.
    What voltage 1kv? Not specified. Enough to use it as breakdown voltage.
    I found this recently ( amplifier ):
    http://flcelectronics.com/pdf/A800DI.pdf
    But price is not showed there.
  7. ronsimpson
    Apr 17, 2007
    7,304
    969
    Loveland, CO USA
    There you go. Good find. Now you can use almost any "Common signal generator". You need 10 to 15 volts out to drive the amp.
    A 100khz sine wave will look like a sine/triangle wave.
    speed problems:
    The output can only move up/down at a maximum of 300V/uS so a square wave can turn into a triangle.
    The output can not pass anything faster than 200khz so any wave can turn into a sine wave.
    The output can only put 60mA so if you are driving any capacitance the output will be slow. No 50 ohm load.
    This amp is a good audio amp (not driving a 8 ohm speaker) but you will not get "RF" out of it.
  8. OBW0549
    OBW0549 Member
    Apr 26, 2015
    97
    26
    Southeast PA, USA
    I don't know that I'd trust that thing: at one point the document states, "Any function or arbitrary waveform generator with low output impedance and output voltage up to ±10 V can be used as an input device." Yet just a few paragraphs later it cautions, "The amplitude of the input signal should normally be kept within ±4 V." On the following page it again says, in bright red print, "Keep input signals within ±4 V range" and in the diagram on the page after that, the input is shown with a label saying "±4 V."
    Is the ±10 V a misprint? Or the ±4 V? One or the other must be wrong. And if the maximum input is ±4 V, and the amplifier gain is 100, ±400 V is all you're going to get out of this thing.
  9. JimB
    Sep 11, 2004
    6,353
    586
    Peterhead, Scotland
    ONLINE
    Just to be pedantic and frivolous...
    Sine wave - a squiggly mathematical electrical thing.
    Signwave - a company who make signs - https://www.signwaves.co.uk/
    • Like Like x 1
    • Thanks Thanks x 1
  10. ronsimpson
    Apr 17, 2007
    7,304
    969
    Loveland, CO USA
    "800 Vpp" is 8v Vpp input or +/-4V.[/quote]
  11. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,080
    326
    Brisbane Australia
    How can they state an output voltage of 1600Vpp when it clearly can't manage that? I can see that 4Vpp can become 400Vpp and 800Vpp with the phase inverter but how can 1600Vpp be achieved.
    Did I miss something?
  12. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,934
    1,099
    I know you asked about function generators, but you did not really give anything to go on. For measurements check out Tektronix/Keithley and Agilent SMU's (Source Measure Units) I think some can have programs downloaded to them. They are not function generators.
Share This Page
