    Dismiss Notice
For windmill project..
Discussion in 'Alternative Energy' started by pablome, Mar 12, 2009.
  1. pablome
    pablome New Member
    Feb 9, 2007
    72
    1
    Ill have a dc motor that will generate voltage from the couple blades. What kind of battery should I use(preferably 12v) that will be coming from a charge controller.
  2. Jules_Theone
    Jules_Theone Member
    Jan 22, 2009
    167
    3
    Exeter, England
    What voltage do you have from the DC motor? How many amps? Which charge controller do you have?
    Anyway, I would suggest lead-acid batteries because they are cheap, and can deal with punishment.
  3. pablome
    pablome New Member
    Feb 9, 2007
    72
    1
    Jules_Theone -------------What voltage do you have from the DC motor? How many amps? Which charge controller do you have?
    Anyway, I would suggest lead-acid batteries because they are cheap, and can deal with punishment. ---------------
    DC motor is supposed to generate 12V DC. 1Amp..or thats after the inverter, 12Vac 1 amp. 50 W i think.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Jules_Theone
    Jules_Theone Member
    Jan 22, 2009
    167
    3
    Exeter, England
    I don't understand -
    12v x 1A = 12W
    or
    50W/12V = 4.1A
    12Vac = 12v x 1.41* = 16.8Vdc
    * (RMS)
    13.8V is ideal for charging lead acid batteries, with the two diode drop from 16v it will be ok.
    If you're using an inverter, that should have a battery low shut-down to stop the battery discharging too much, but it's also an idea to us a wind charger controller that can dump energy into a load when it's very windy or when the battery is fully charged.
    I have a simple FET voltage clamp that dumps load into a high power resistor in a bucket of water when the voltage goes over 14v.
  6. pablome
    pablome New Member
    Feb 9, 2007
    72
    1
    The 50W after the inverter, that makes more sense.
  7. Thunderchild
    Thunderchild New Member
    Jul 3, 2005
    2,294
    9
    UK
    the inverter won't create power only up your input voltage and loose you 10 % of the wattage in the process (90 % efficient inverter)
Share This Page
