    Dismiss Notice
For loop help.
Discussion in 'Microcontrollers' started by be80be, Oct 21, 2017.
  1. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,829
    138
    morristown,tn
    ONLINE
    I did this last night the first for loop works the second one doesn't.
    I can't for the life of me figure it out.
    Code (text):
     PWM1_Initialize();
        while (1)
         uint16_t load;
         uint16_t dutycycle;
         for (load = 0; load < 0x03FF; load++)
         __delay_ms (500);
         dutycycle = load;
         PWM1_LoadDutyValue(dutycycle);
          for (load = 0x03FF; load > 0x03FF; load--)
            dutycycle = load;
  2. be80be
    Aug 23, 2008
    4,829
    138
    morristown,tn
    ONLINE
    If I just do this loop it just sits here full on
    Code (text):
    while (1)
         uint16_t load;
         uint16_t dutycycle;
            dutycycle = load;
  3. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,294
    647
    Derbyshire, UK
    ONLINE
    Your variable test is wrong - you're testing for it been greater than 0x3ff, and it never is as it starts at that, and then decreases.
    • Like Like x 1
    • Agree Agree x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. be80be
    Aug 23, 2008
    4,829
    138
    morristown,tn
    ONLINE
    I kind of was thinking that but I tried the => it didn't work too. I'm going to test for less
    thanks this c stuff is not that easy i looked up for loops nothing in xc8 about going less
    lust ++ lol
  6. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,083
    326
    Brisbane Australia
    ONLINE
    Assuming you want the loop to go from 0 to 0x3ff then your for loop should be,
    Code (text):
        for(load=0;load<0x400;load++){
    To go backwards is a little tricky with unsigned integers as you can't test for -1. So a test for above 0x400 will detect when it's gone negative.
    Code (text):
        for(load=0x3ff;load<0x400;load--){
    The above loop will terminate when load is 0xffff and therefore no longer less than 0x400.
    Hope that makes sense.
    Edit, it would make the code much more readable to test for not equal to oxffff;
    Code (text):
        for(load=0x3ff;load!=0xffff;load--){
  7. be80be
    Aug 23, 2008
    4,829
    138
    morristown,tn
    ONLINE
    Yep the 0 test don't seem to work and the arduino type test don't work with xc8 no errors just don't do nothing.
    >= didn't work Im going to try it your way mike thanks
  8. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,250
    911
    Rochdale UK
    Uint16 cannot be lower than 0... You need it to be a signed int to use " load>0 " Mikes alternative is better for Unsigned...
  9. be80be
    Aug 23, 2008
    4,829
    138
    morristown,tn
    ONLINE
    I'm i was just testing the load be from
    0 to 1023 from the adc
  10. Beau Schwabe
    Beau Schwabe Member
    Jun 4, 2017
    32
    5
    Shouldn't the second one just read ...
    Code (text):
          for (load = 0x03FF; load > 0; load--)
            dutycycle = load;
  11. Pommie
    Mar 18, 2005
    10,083
    326
    Brisbane Australia
    ONLINE
    That will only execute from 0x3ff down to 1 - not 0 as required.
  12. Pommie
    Mar 18, 2005
    10,083
    326
    Brisbane Australia
    ONLINE
    For anyone struggling with for loops in C,
    Try going to https://www.onlinegdb.com/
    and copy this into the page,
    Code (text):
    #include <stdio.h>
    #include <stdint.h>
    int main(){
        uint16_t i,j;
        for (i = 0x03FF; i != 0xffff; i--){
            j=i;
        printf("Value of i is %d (0x%x) and j is %d (0x%x)",i,i,j,j);
        return 0;
    Because the test (i!=0xffff) is done after the decrement the value of J is zero and i is 0xffff.
    You can set breakpoints at various points and see whats happening.
    Happy playing.
    • Thanks Thanks x 1
  13. be80be
    Aug 23, 2008
    4,829
    138
    morristown,tn
    ONLINE
    Mike thats a great site I been looking for just a way to do that writing files and testing with C on linux works but that is easy put code and see what happens cool Thinks Mike
Share This Page
