error embedded c code
bhavyam1234
In the embedded c code below it is written for password checking. This code does not give syntax error but for every correct password also is displays "pass is wrong".
C:
#include <AT89X51.H>
#define EE_SCL P1_0
#define EE_SDA P1_1
#define LCD_E P1_7
#define LCD_RW P1_6
#define LCD_RS P1_5
#define LCD_DATA P3
#define buzz P0_3
#define led P1_2
void cmnwrt(int);
void datawrt(char);
char keypad_refresh();
void init();
void delay(unsigned i);
void get_sntnc(char *);
void print_msg(char*,char);
void EE_write(unsigned int, char);
char EE_read(unsigned int);
void EE_strt();
void EE_stop();
char EE_shin();
void EE_shout(char);
int main()
    char tmp[17];
    int i,j;
    init();
    cmnwrt(0x80);
    led=1;
    while(1)
        if(EE_read(0)!='p'||EE_read(1)!='=')
np:
            cmnwrt(1);
            print_msg("Enter new pass:\0",0x80);
            get_sntnc(tmp);
            EE_write(0,'p');
            EE_write(1,'=');
            for(i=0;tmp[i];i++)
            EE_write(i+2,tmp[i]);
            EE_write(i+2,0);
rpa:
        cmnwrt(1);
        print_msg("Enter the pass:\0",0x80);
        get_sntnc(tmp);
        for(i=0,j=0;;i++)
            if(tmp[i]!=EE_read(i+2))
                j=-1;
                break;
            if(!tmp[i])
                break;
        cmnwrt(1);
        if(j==-1)
            print_msg("Pass is wrong!\0",0x80);
            led=1;
            buzz=1;
            delay(5000);
            buzz=0;
            goto rpa;
        else
            print_msg("Pass is right!\0",0x80);
            led=0;
            buzz=0;
            delay(5000);
            led=1;
        cmnwrt(1);
        print_msg("*=change pass\0",0x80);
        print_msg("#=back\0",0xc0);
ka:
        do
        i=keypad_refresh();
        while(i==-1);
        if(i==0x3a)
            goto np;
        else if(i==0x3c)
            goto rpa;
        else
            goto ka;
void print_msg(char *msg, char line)
    char i;
    cmnwrt(line);
    for(i=0;*(msg+i);i++)
    datawrt(*(msg+i));
    char tmp,row,cl;
    P2 = 0xf0;
    if(!P2_4)
        row = 0;
    else if(!P2_5)
        row = 1;
    else if(!P2_6)
        row = 2;
    else if(!P2_7)
        row = 3;
    else
        return -1;
    P2 = 0xff;
    P2 = 0x0f;
    if(!P2_2)
        cl = 0;
    else if(!P2_1)
        cl = 1;
    else if(!P2_0)
        cl = 2;
    else
    return -1;
    tmp = row*3+cl+1;
    if(tmp == 11)
    tmp = 0;
    return tmp|0x30;
void get_sntnc(char *str)
    char i,j,z;
    for(i=0;i<17;i++)
    *(str+i)=0;
    i=0;
    while(1)
        cmnwrt(0xc0);
        for(z=0;z<16;z++)
            if(*(str+z))
                datawrt(*(str+z));
            else
                datawrt(' ');
        delay(70);
        do
            j = keypad_refresh();
        while(j==-1);
        if(j==0x3c)
            *(str+i)=0;
            break;
        else if(j==0x3a)
            if(i>0){
            i--;
            *(str+i)=0;
        else
                if(i<=15)
                *(str+i)=j;
                i++;
void init()
    int i;
    P0=P1=P2=P3=0;
    //initialize LCD
    LCD_RS = 0;
    LCD_RW = 0;
    delay(30);
    cmnwrt(0x3f);
    delay(20);
    cmnwrt(0x3f);
    delay(10);
    cmnwrt(0x3f);
    delay(5);
    cmnwrt(0x38);
    cmnwrt(0x01);
    cmnwrt(0x0c);
    //initialize EEPROM
    EE_SDA = 1;
    for(i=0;i<10;i++)
        EE_SCL = 1;
        i=i;         //delay
        EE_SCL = 0;
    TMOD = 1;
    for (;i>0;i--)
        TH0 = 0xFc; //0xFFFF - 0xFc17 = 1000 (decimal) -> 1ms for 12MH crystal
        TL0 = 0x17;
        TR0 = 1;
        while(!TF0);
        TR0 = 0;
        TF0 = 0;
void cmnwrt(int cmn)
    LCD_DATA = cmn;
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_E = 1;
    LCD_E = 0;
    delay(2);
void datawrt(char ch)
    LCD_DATA = ch;
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_E = 1;
    LCD_E = 0;
    delay(2);
//Write into EEPROM
void EE_write(unsigned int addr, char dta)
    char chtmp;
    CY = 0;
    EE_strt();
    EE_shout(0xA0);
    chtmp=addr>>8;
    EE_shout(chtmp);
    chtmp=addr;
    EE_shout(chtmp);
    EE_shout(dta);
    EE_stop();
    delay(13);
//Reading from EEPROM
char EE_read (unsigned int addr)
    char chtmp;
    CY=0;
    EE_strt();
    EE_shout(0xA0);
    chtmp=addr>>8;
    EE_shout(chtmp);
    chtmp=addr;
    EE_shout(chtmp);
    EE_strt();
    EE_shout(0xA1);
    chtmp=EE_shin();
    EE_stop();
    return chtmp;
//Start
void EE_strt()
    EE_SDA=1;
    EE_SCL=1;
    EE_SDA=0;
    EE_SCL=0;
//Stop
void EE_stop()
    EE_SCL=0;
    EE_SDA=0;
    EE_SCL=1;
    EE_SDA=1;
//Shift out
void EE_shout(char sho)
    unsigned char i,j;
    for(j=0,i=0;i<8;i++)
        j/=2;
        if(!j)
        j=128;
        if(sho&j)
        CY=1;
        else
        CY=0;
        EE_SDA=CY;
        EE_SCL=1;
        j=j;         //delay
        EE_SCL=0;
    EE_SDA=1;
    EE_SCL=1;
    j=j;             //delay
    CY=EE_SDA;
    EE_SCL=0;
//Shift in
char EE_shin()
    char i,shi = 0;
    EE_SDA = 1;
    for(i=0;i<8;i++)
        CY=0;
        shi<<=1;
        EE_SCL=1;
        i=i;
        CY=EE_SDA;
        EE_SCL=0;
        if(CY)
        shi++;
    EE_SDA=1;
    EE_SCL=1;
    i=i; //delay
    EE_SCL=0;
    return shi;
Write a debug code that displays the current password stored in memory.. check if that is correct.
