ECG device
Hi ccurtis
i will try to connect the AD624 as shown in the link you post, after the the low pass filter i have to us ADC 12bit resolutions by the way i am using the DAQ NI-USB 6008 student edition and i connect direct to the labVIEW as a driver by its self. so my question is that possible and by the way after i check the signal i have to send it using bluetooth module wireless transmission and the labVIEW should acquire the signal by this way.......
thanx 4 any help
hi i am also building the ecg circuit and was having problems in it. avoid using op amps in the circuit. try using passive filters. cause after using notch filter the op amp adds us the noise again. the t diagram of capacitors and resistors u used is a notch filter it self using op amp 741 u are just buffering the signal and also thus adding the 5ohz noise u wished to remove. i got some what results of ecg. i will soon post the circuit diagram. us passive filters only. build the drive leg circuit and ground it. after ad620 give a 1000 gain to the signal. and use passive low pass and high pass filter. u will get the results
