Sounds a good strategy.
What are Ron's changes? I seem to have missed them.
Jeremy,
You did say your regular voltmeter showed the voltages to be stable?
I was thinking I would build it and then IF it is still unstable with the mods that ronv made I will then look into getting a scope. I think the only risk in that strategy is I may have to do some re-work...but if it is stable I may be able to say the cost of scope.
ronv said:We could also try to turn it off instead of shorting out the big power supply.
...The last method allows the possibility for us to power the dummy load off the DUT, which could be nice.
Guys,
I have a couple of questions that may seem silly but I’ll go ahead and ask them anyway for my own enlightenment. Here goes:
- Why not use a precision voltage reference instead of a voltage divider hung off Vcc to derive Vref?
- Why not ditch the x10 amplifier that generates a guesstimate of the output current reading and replace it with a summing amp that gives the actual current reading regardless of how many FETs are working?
Guys,
We could do that I guess, but the reference doesn't need to be precise since the current is dialed in. It is a regulated supply so it should be stable.
-Why not ditch the x10 amplifier that generates a guesstimate of the output current reading and replace it with a summing amp that gives the actual current reading regardless of how many FETs are working?
That's a good idea, but Jeremy's about just putting in a real ammeter is the best. Then it doesn't matter how many FETs or what value sense resistor we use.
...That's a good idea, but Jeremy's about just putting in a real ammeter is the best. Then it doesn't matter how many FETs or what value sense resistor we use.
True, I just thought that since one of Jeremy's goals was to improve stability it couldn't hurt (and they're relatively cheap). If my math is right, 10mv on the reference controls about an amp of load so it doesn't take much noise or drift to swing the load around.We could do that I guess, but the reference doesn't need to be precise since the current is dialed in. It is a regulated supply so it should be stable.
Here is an electronic circuit breaker that might work. It won't be easy to debug if doesn't. What do you guys think.
https://www.electro-tech-online.com/custompdfs/2013/01/mic5031.pdf
