    Dismiss Notice
DS1302 with PIC16f877 program
Discussion in 'Microcontrollers' started by RasCreationKing, Jun 1, 2006.
  1. pyrodigy
    pyrodigy New Member
    Jul 19, 2006
    4
    0
    Hi phamthaihoa,
    I am currently working on a project RTC DS1307 with 16f877,so i would be very glad if you share your source code with me.
  2. falsami
    falsami New Member
    Jul 19, 2006
    1
    0
    Sam
  3. masud58
    masud58 New Member
    May 14, 2004
    15
    0
    Dhaka
    may help
    it is use keil for at89c51 and ds1307.
    simulate with proteus
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. RasCreationKing
    RasCreationKing New Member
    May 29, 2006
    11
    0
    Greetings Everyone!
    After some time putting things together, I have thought to come up with the project that will monitor the BATTERY VOLTAGE(24 V) and display it on LCD.I am currently researching about the similar design. I thought it will be best to share this with my Online friends and tutors to help me with ANALOG to DIGITAL converter using PIC16f877 to monitor input(Battery) voltage and display it on LCD. Any help is greatly appreciated.
    Yours Truly,
    Ras Creation King
  6. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,235
    641
    Derbyshire, UK
    ONLINE
    Check my tutorials, which have everything you require!.
  7. PKSURYA
    PKSURYA New Member
    Mar 26, 2007
    1
    0
    SIR, Phamthaihoa
    i read ur quote that u have code for Pic16f877a with rtc ds1307, sir need ur help i want to develop code for display date/time in normal and while taking reading with the any detector signal which is 0-5volt Analog and does 10bit adc and display result in precentage 0.0-100.0% on LCD 16x2 and keep hold till button is not pressed for other reading and then store that read with date and time in its flashmemory. and suggest keypad numder is required for clock setting and other perpuse.
    thank u
    PK SURYA
    "Originally Posted by phamthaihoa
    If you use DS1307, i will post my source code I done 1 year before.
    I've done it, I used 16F877A and DS1307, display year, data, time on LCD 16x2."
  8. gramo
    gramo New Member
    Oct 2, 2006
    1,221
    23
    Newcastle, Australia
    Sigh, if only you knew how easy this would be in a higher language such as Proton PIC Basic..
    Code (text):
    Device = 16F876
    Xtal = 4
    ALL_DIGITAL = True
    PORTB_PULLUPS = True
    ' Setup the LCD
    LCD_DTPIN = PORTB.4
    LCD_RSPIN = PORTB.2
    LCD_ENPIN = PORTB.3
    LCD_INTERFACE = 4
    LCD_LINES = 2
    LCD_TYPE = 0
    ' Define I2C bus ports
    SDA_Pin = PORTA.0 'DS1307 SDA pin
    SCL_PIN =PORTA.1 'DS1307 SCL pin
    Dim Temp1 As Byte
    Dim Temp2 As Byte
    Dim TempVal As Byte
    Dim Secs As Byte
    Dim Mins As Byte
    Dim Hrs As Byte
    Dim day As Byte
    Dim Date As Byte
    Dim Month As Byte
    Dim Year As Byte
    Dim Ctrl As Byte
    Dim Secs_last As Byte
    'Initialize LCD
    Delayms 100
    Cls
    ' Set initial DS1307 time / Date
    Secs = 0                     ' Set seconds
    Mins = 30                    ' Set minutes
    Hrs = 12                      ' Set hours
    Day = 1                       ' Set day of week value
    Date = 30                     ' Day of month value
    Month = 11                   ' Month value
    Year = 6                       ' Year value
    Ctrl = 0                        ' Set the control byte (leave as 0 in this example)
    ' The DS1307 works with data in BCD format, so convert BIN to BCD
    TempVal=Secs
    GoSub BIN_TO_BCD
    Secs=TempVal
    TempVal=Mins
    GoSub BIN_TO_BCD
    Mins=TempVal
    TempVal=Hrs
    GoSub BIN_TO_BCD
    Hrs=TempVal
    TempVal=Day
    GoSub BIN_TO_BCD
    Day=TempVal
    TempVal=Date
    GoSub BIN_TO_BCD
    Date=TempVal
    TempVal=Month
    GoSub BIN_TO_BCD
    Month=TempVal
    TempVal=Year
    GoSub BIN_TO_BCD
    Year=TempVal
    BStart
    ' The datasheet specifies the first byte is 1101000x where x is read(1) or write(0).
    ' The second byte tells the DS 1307 where to start reading, 0 is at the start.
    ' The Ctrl byte contains advanced features, read the datasheet for more info
    Busout 11010000, 0, [Secs, Mins, Hrs, day, Date, Month, Year, Ctrl] 'Write initial values for time / Date
    BStop
    Delayms 20
    Main:
    BStart
    BusIn 11010001, 0, [Secs, Mins, Hrs, day, Date, Month, Year, Ctrl]
    BStop
    ' The DS1307 sends it data in BCD, therefore it must be changed to
    ' BIN so that it can be easily used (eg, print onto an LCD)
    TempVal=Secs
    GoSub BCD_TO_BIN
    Secs=TempVal
    TempVal=Mins
    GoSub BCD_TO_BIN
    Mins=TempVal
    TempVal=Hrs
    GoSub BCD_TO_BIN
    Hrs=TempVal
    TempVal=Date
    GoSub BCD_TO_BIN
    Date=TempVal
    TempVal=Month
    GoSub BCD_TO_BIN
    Month=TempVal
    TempVal=Year
    GoSub BCD_TO_BIN
    Year=TempVal
    If Secs - Secs_last = 0 Then Goto Main                'If there is update in Secs, display time and Date
    ' The Dec2 modifier makes sure that each value will have 2 characters, eg 1 becomes 01
    Print At 1,1,"Time: ",Dec2 Hrs, ":", Dec2 Mins,":", Dec2 Secs
    Print At 2,1,"Date: ", Dec2 Date, "-", Dec2 Month, "-", Dec2 Year
    Secs_last = Secs
    Goto Main
    BCD_TO_BIN:                                    ' Convert the BCD values into BIN
         Temp1 = $0F & TempVal                     ' Clear off the top four bits
         Temp1 = DIG Temp1, 0
         Temp2 = TempVal >> 4                       ' Shift down four to read 2 BCD value
         Temp2 = DIG Temp2, 0
         TempVal = Temp2 * 10 + Temp1
         Return
    BIN_TO_BCD:
         Temp1 = Dig TempVal, 0                     ' GET THE DEC DIGIT FOR THE FIRST NIBBLE
         Temp2 = Dig TempVal, 1                     ' GET THE DEC DIGIT FOR THE FIRST NIBBLE
         Temp2 = Temp2 << 4                          ' MOVE NUMBER OVER TO 2ND NIBBLE
         TempVal = Temp1 ^ Temp2                  ' XOR THEM TOGTHER TO MAKE THE WHOLE BCD NUMBER
         Return
    Click here to watch this circuit in action
    [​IMG]
  9. vinodh_simon
    vinodh_simon New Member
    May 3, 2007
    1
    0
    Can any of you help me in getting the instruction sets and thier functionalities for PIC16F877. Please give me the link.
  10. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,190
    644
    Ex Yorks' Hants UK
    ONLINE
Share This Page
