Doppler Shift Detection
Cihan Tunca
Hi!
I'm working on a lidar system. I need your help to desing an important part of the system. It is the frequency shifting detection. I have to detect the Doppler shift to calculate the velocity of a moving target. At this point I couldn't find out a circuit to do this detection for me. I will be waiting for your advices to detect the Doppler shift and calculate the velocity of the target using different ways at the next a few weeks.
Thanks.
What is the approximate target velocity?
The AD8302 has a 2.7GHz bandwidth. Will that be sufficient for detecting Doppler shifts of optical frequencies (~hundreds of THz)?
I'm not trying to detect doppler shift at the optical frequencies. I'm going to modulate the light at aproximately 1 GHz such a sin wave or pulse train which has quite low duty cycle values,
I think, I don't need amp. I'm planing to use APD photo detector to collect the reflected light and it's output current is enough to process using an PIC, I think.
So, you propose to compare the frequency of the modulating signal with the shifted frequency of the demodulated signal? If so, a simple mixer followed by a low pass filter should work to provide the difference frequency; perhaps something like the AD8343 with an R-C lowpass filter.
