My circuit doesn't use opamps. It uses two of the 6 inverters in a CD4069 hex (6) inverters Cmos logic IC.mvadu said:And what is the OP-Amp IC used in that circuit?
audioguru said:My circuit doesn't use opamps. It uses two of the 6 inverters in a CD4069 hex (6) inverters Cmos logic IC.
Good idea.audioguru said:One time I had a 240VAC fan that wouldn't run on my 120VAC mains. So I tuned it to my mains frequency with a capacitor in series and it ran fine. It developed about 190VAC.
It wouldn't make any difference to the piezo, but it would to the driver; the driver will see a higher impedance load but still supply the same current to the piezo. Just like the parallel power factor correction capacitor in a fluroscent ube fitting; the tube might draw 1A but the with the capacitor the totaly load on the supply might only be 0.4A.A coil in parallel would not allow the piezo transducer to draw much current because then it would be in a high impedance tuned circuit, wouldn't it?
mneary said:You need to measure the reactance of the piezo at the output frequency and put a series reactance to counteract this, forming a low impedance load.
This could result in a high output, an overloaded driver, or a shattered piezo.
