    Dismiss Notice
[DISCUSSION] Electronic combination lock based on PIC
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by alkoko111, Jul 14, 2009.
  1. alkoko111
    alkoko111 New Member
    Jun 29, 2009
    23
    0
    yemen / aden city
    how are everbody ..... i have a topic to discuss about togather .
    I've being thinking of implement the Electronic combination lock project. therefor I decided to discuss it with you first.
    Befor we go deeply , let's first discuss the component we need.
    because it is based on PIC, then the first component is :
    I suggest
    1\ PIC16F628.
    while our project will work on the AC supply of the home electricity, then :
    2\ transformer . Is there a specific one should i choose ?
    I suggest to add a serial LCD screen, then :
    3\ HD44780-compatibe 2x16 char LCD. do you think this better ?
    The last component :
    4\ electrical lock of the door .
    WHAT DO YOU THINK GUYS ? WHAT DO YOU SUGGEST?
  2. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    There are so many unkowns in your project....
    How many digits do you require for the combination? 2,4,8.....
    What is the ac supply for the house? Do you need to battery back your unit for security incase of mains fail?
    What does the lcd display do? What are you expecting to see?
    What is the electronic bolt securing? a door?
    What are its electrical requirements as this will determine the transformer needed.....
    I detect a little deja vue here....
  3. House0Fwax
    House0Fwax Member
    Nov 15, 2006
    583
    17
    Hampshire U.K.
    Using a 3 x 4 keyboard and a 4 bit LCD doesn't leave any pins left to opperate the lock.
    Use a pic with more pins. 16F876 for example.
    (based on my experiences using Nigel's tutorials)
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. alkoko111
    Jun 29, 2009
    23
    0
    yemen / aden city
    4 digits
    220V OR 110V
    Tell me about this please, i have no idea about this .
    Tell me what do you suggest, I have no idea
  6. alkoko111
    Jun 29, 2009
    23
    0
    yemen / aden city
    where can I find these tutorials?
  7. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    WinPicProg Page
  8. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    My question was why does he need an lcd? What benefit does it provide?
    the orig pic would do the job without reverting to more code
  9. alkoko111
    Jun 29, 2009
    23
    0
    yemen / aden city
    what about the circuit diagram ?
  10. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    What about it?
  11. alkoko111
    Jun 29, 2009
    23
    0
    yemen / aden city
    i mean how we are going to wire the components together ?
  12. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    Have you got a schematic of this to work from?
    Start with building blocks...Draw up a power supply first and get that to work...
  13. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,216
    640
    Derbyshire, UK
    It lets you see the digits as you type them in - and it looks cool :D
  14. Boncuk
    Boncuk New Member
    Nov 10, 2007
    5,382
    88
    Phetchabun,Thailand
    and if a wrong number is put in it displays: * SYNTAX ERROR * (fits exactly in the first line), and * HANDS OFF ! * (fits exactly in the second line) :D
  15. Chippie
    Chippie New Member
    Mar 8, 2003
    991
    9
    Good 'ole England
    bells and whistles....
  16. alkoko111
    Jun 29, 2009
    23
    0
    yemen / aden city
    ok guys .....what do you suggest the schematic will be ?
  17. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Have you tried Google for 16F877 & LCD. Lots of schematics online.
    I'm guessing this is a school project.
  18. marcbarker
    marcbarker New Member
    Jul 5, 2009
    727
    7
    London, UK
    It lets you see the digits as you type them in Not if you're blind it don't :)
    Since an entered PIN number or password is usually shown anyway as * * * * , means just 4 LEDS could be used, each with a * painted on it!
    PIC software for reading the keys is easy peasy: Use a 3:4 matrix keypad out of a telephone. interface it to PIC. Make the PIC assert H's to the Rows. Poll the Columns (or use an ISR) looking for keypresses. When the keypress has been there for 200 ms, drop the rows one at a time until find which key is pressed. Do the 'drop rows routine' a few more times again to make sure, and good to do a do a 'best of 30' to exclude contact noise. Pulse an output to make a 'beep' sound for about 500 ms, and poke the data into whatever register is waiting for it. Hang around and wait for the key to unpress, and then wait some more time (about a second) before resuming the polling. If another keypress isn't detected after a 5 second timeout, sound a long beep to say pin entry "cancel!" If the 4 key numbers match the sequence already programmed into the PIC software, pulse the lock solenoid via mosfet driver. Which could be something like a solenoid bolt, or an small electric motor like they do on electric cat-flaps.
  19. alkoko111
    Jun 29, 2009
    23
    0
    yemen / aden city
    i found this schematic on the google designed by Peter JAKAB :
    [​IMG]
    what do you think guys ?
    marcbarker ..... could you clearify the algorithm of keypresses ?
  20. marcbarker
    Jul 5, 2009
    727
    7
    London, UK
    the schematic is about exactly what i had in mind, but if i did it the BOM would be smaller. i'd pic a pic wiv osc built in.
    no i won't claerify the keyscan algorithm, i haven't got time today :)
  21. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Like the 16f628A
Share This Page
