Dimming a LED using 8051.
ikelectro
I want to make a LED glow slowly. But haven't succeed yet. I learn only these command still now over one and half month : mov, add, clr, setb, djnz, lcall, cjne, rr, rl, swap, jnb, jb, ret, nop, jmp, sjmp, jz, jnz. So, is it possible to make a led dimmer with with these instruction?
I think that is most of them...
The two you need are SETB and CLR.... these turn off / on an LED connected ( via a transistor ) to a micro pin..
you then place the code in a forever loop with a variable delay between these two commands
var1   equ   250     ; on time
var2   equ   50     ; off time
loop:
   mov   R0, #var1
   setb   P0.0
on:
   djnz   R0, on     ; wait here for on time
   mov   R0, #var2
   clr    P0.0
off:
   djnz   R0, off    ; wait here for off time
   jmp   loop
end
Something like this... To make the LED come on slowly... Increase var2 while decreasing var1..
